Replaced distributor, car still wont start, HELP!
Old Sep 24, 2004 | 06:26 PM
  #41
Ochdx's Avatar
Ochdx
well, i visually inspected that wire, seemed fine. plus, if the engine wasnt grounded, there wouldnt be a spark between the plug and engine, but there is
  #42
Ochdx's Avatar
Ochdx
ill just tow it to mechanics next weekend, i've had enough
Old Sep 24, 2004 | 06:34 PM
  #43
XScarAudio's Avatar
XScarAudio
///o\\\///o\\\
Sorry i couldnt help more. Post the results!
Old Sep 25, 2004 | 11:19 AM
  #44
NeverBX's Avatar
NeverBX
Snootchie Bootchies!!
what kind of spark plug wires are you running? if you're running anything but NGks put the stock ones back on and try it.
Old Sep 25, 2004 | 12:26 PM
  #45
Ochdx's Avatar
Ochdx
well, injectors seem to work because if i attempt to start the engine, and then pull the plug right away, the bottom is all wet in gas
Old Sep 25, 2004 | 01:20 PM
  #46
NeverBX's Avatar
NeverBX
well what about the spark plug wires?
Old Sep 25, 2004 | 02:14 PM
  #47
Ochdx's Avatar
Ochdx
well, the plugs are sparking, so i would imagine the wires are ok
Old Sep 28, 2004 | 04:10 PM
  #48
randbcustoms's Avatar
randbcustoms
all go no show racing
ok.. so you have spark and fuel getting to the plugs..but no one has mentioned the possiblity of loss of compression...put a compression gauge on all the cylinders they should all be over 100 psi and within 10 percent of each other.. if you don't have a compression gauge..sears sells cheap ones ($20)......compression , spark and fuel are the only things that are needed for the engine to run..granted the air/fuel ratio has to be correct and the spark has to be timed.. but with those three present the car should run...good luck
Old Sep 28, 2004 | 06:58 PM
  #49
XCM828's Avatar
XCM828
stay off of wet roads
from my experience, ive learned that its usually one of ten things wrong when the engine rotates but wont start. you have already ruled out most of these but here is the list in case anyone needs it for future reference.
1. Fuel tank empty.
2. Battery discharged.
3. Battery terminal connections loose or corroded.
4. Leaking fuel injectors, faulty fuel pump, pressure regulator, etc.
5. Fuel not reaching fuel rail.
6. Ignition components damp or damaged.
7. Worn, faulty or incorrectly gapped spark plugs.
8. Broken, loose or disconnected wiring in the starting circuit.
9. Loose distributor is changing ignition timing.
10. Broken, loose or disconnected wire at the ignition coil or faulty coil.
So pretty much make sure everything is tight, flowing, and dry. Hope this helps.
