I'm going to build my first computer system, i need critiquing...
Old Jun 23, 2004 | 06:24 AM
  #101
Andy's Avatar
Andy
Hybrid Forum Moderator
Tell you what, this going to sound dumb but try it, it worked for me before. Shut down both computers, and unplug the cable modem (don't just turn the swtich off). Go in the other room and get a drink of something. Like reseting the computer in your car by pulling the negative terminal, some cable modems may have memory and remember the MAC address of the computer they were hooked to. They probably eventually update once in a while but this is a way to force it. After leaving it unpluged for a few seconds, plug the cable modem back in (to the new computer too) and let it go through it's diagnoistic light flashes. Once it's stable, turn your new computer on, hopefully the cable modem will see the computer and establish it's connection. If it doesn't, try the run/cmd then ipconfig /release ipconfig /renew.
What OS is on your old computer? It's possible your ISP doesn't use DHCP and your given a static address. If that doesn't work, we'll have to check the old computer for an IP.
Old Jun 23, 2004 | 06:27 AM
  #102
spanky's Avatar
spanky
I go duffy on dem bitches
Originally Posted by brtecson
Yep, modem is on. I have been switching the cable from my modem back and forth from the old comp (that works) and the new system that doesn't want to cooperate.
is it pulling a valid ip address? if not move the nic to a different slot.
if so, its prboably winsock issues. pm me for a fix
Old Jun 23, 2004 | 11:09 AM
  #103
brtecson's Avatar
brtecson
pukimonster
ok i'll try that when i'm home
Old Jun 23, 2004 | 11:10 AM
  #104
brtecson's Avatar
brtecson
pukimonster
i believe so.
Old Jun 23, 2004 | 12:15 PM
  #105
Andy's Avatar
Andy
He's using the built in NIC as far as I can tell and it's not getting a valid IP because the DHCP refresh is timing out (assuming his ISP uses DHCP). Your using using XP right? I haven't even seen winsock since dialing up on a win95 machine.
Old Jun 23, 2004 | 01:38 PM
  #106
brtecson's Avatar
brtecson
pukimonster
yep, xp pro.
Old Jun 23, 2004 | 01:40 PM
  #107
brtecson's Avatar
brtecson
pukimonster
i wish i was at home so i could fiddle with it:happysad: sigh.
Old Jun 23, 2004 | 02:29 PM
  #108
lil_1_2002's Avatar
lil_1_2002
damn bro how long ahve u been trying to fix this PC? i hope i can get my stuff ready and working without problems....
Old Jun 23, 2004 | 02:51 PM
  #109
Grifter's Avatar
Grifter
:werd:
Old Jun 23, 2004 | 09:37 PM
  #110
Andy's Avatar
Andy
Any luck? I want to know if this thing is working yet or not?
