I'm going to build my first computer system, i need critiquing...
Old Jun 22, 2004 | 12:23 AM
  #91
wedley2's Avatar
wedley2
bboy Wesley West
Originally Posted by brtecson
connected directly thru the cable modem. no dailing.
okay, so u connect to modem (leave modem on and computer on) do the status lights come on for the NIC card? i thik you said it does but cannot connect through internet explorer? what color are th lights in back? if its green, status should mean good and yellow means not communicating but connected.
Old Jun 22, 2004 | 12:48 AM
  #92
brtecson's Avatar
brtecson
pukimonster
the lights are a orange color. and i'm using the mobo's onboard setup, no nic
Old Jun 22, 2004 | 01:03 AM
  #93
wedley2's Avatar
wedley2
bboy Wesley West
hmmm, so its not communicating with the modem...
Old Jun 22, 2004 | 01:29 AM
  #94
Anthony's Avatar
Anthony
ZOMG Pew Pew Laserbeams
gah if only u were in CA i could look at it and see what the problem is but i think it's just a hardware issue more so to do with ur cable modem and ur onboard lan at the moment
Old Jun 22, 2004 | 10:14 AM
  #95
Andy's Avatar
Andy
Hybrid Forum Moderator
Originally Posted by SOLDIER [X]
i'm using an asus intel mb with an ati video card it works perfectly fine.
I didn't mean that an ATI card won't work with an ASUS board (I'm running the same MB he is with a 9800 Pro) but someone else was suggesting that he go get the newest drivers from Nvidia which obviously won't work (it's not an NForce2 chipset).
I'm assuming the drivers loaded correctly and the device manager shows the ethernet adaptor to be working correctly.
Right click on my network places and go to properties. Inside there should be Local Area Connection icon and it should be enabled. If there is any icon for a network bridge, right click and remove it. Right click on the Local Area Connection icon and go to properties. Click on Internet Protocal (TCP/IP) and click properties (assuming it's there, if not, add it). Make sure it's set to obtain an IP address automatically and obtain DNS server address automatically (I'm assuming your ISP is similiar to mine and doesn't require a static address).
After all that's setup, close everything and click start, go to run and type cmd. Type "ipconfig /release" and then type "ipconfig /renew". This will force the computer to go out and find a new IP from your ISP and should get you up and running. I'd highly recommend you go pickup a router (I like D-link personally but most are good) so you'll be protected by it's built in NAT addressing and firewall. Even if you only have 1 computer, it's worth being behind something for protection as opposed to be connected right to the cable modem. Hopefully that will get you up and running.
Old Jun 22, 2004 | 01:26 PM
  #96
brtecson's Avatar
brtecson
pukimonster
OK, thanx a lot Andy. I'll try it when I get home:goodjob:
Old Jun 22, 2004 | 10:16 PM
  #97
brtecson's Avatar
brtecson
pukimonster
OK, I tried that but I get this message:
"An error occured while renewing interface Local Area Connection: unable to contact your DHCP server. Request has time out."
:thinking: any ideas?
Old Jun 22, 2004 | 11:09 PM
  #98
Anthony's Avatar
Anthony
erm i think that's more cable modem/cable company problem then ethernet card
Old Jun 22, 2004 | 11:28 PM
  #99
wedley2's Avatar
wedley2
bboy Wesley West
u sure ur modem is on? lol happened to a customer, ended up modem was on standby mode and i still got paid 25 bucks, lol.
Old Jun 22, 2004 | 11:35 PM
  #100
brtecson's Avatar
brtecson
pukimonster
Yep, modem is on. I have been switching the cable from my modem back and forth from the old comp (that works) and the new system that doesn't want to cooperate.
