anyone ever painted a car?
Make the first coat of paint a light mist, nozzle about 24 inches from the surface you're spraying. This helps the paint stick better. Also if the humidity is high, like its raining outside, this helps keep the dust down. Also you might want another coat of color paint to cover the car. It might still be letting some of the primer color through.
Im still looking for some advice slighly more detailed than that....
A good site for alot of diy jobs is on the diy network...
try looking here,then explore the index on the left...lot of cool info to be had there....
http://www.diynetwork.com/diy/ab_aut..._13675,00.html
There is a pretty detailed process on paint there,but you'll prolly end up going thru alot of the index yourself anyways...if your a true diy'er
But maybe someone should bring up how long you should wait inbetween coats,the way i understand it,the longer the better(at least in days vs hours)
Then again,this is somthing i want to get into,not somthing i do.
P.S. also,the angle of how you apply the basecoat is important too....side to side motion on first coat,then a 45degree for the second,or somthing like that...
Whatever,have fun.
Whatever,have fun.
c_rogue69, yes I have painted a car before. This is what I was told to do by a professional. Yes preporation does help it stick, the light mist aids in that also. You only hold the gun 24 inches from the surface for that first mist coat, like I had said. The guy I talked to said since when I was painting it was wet outside that would help keep dust down on the ground and out of the air.
Flash times will depend on humidity /temp.when using base coat ,just wait till the paint flashes,or is hand slick/meaning you can rub your hand quickly along the surface with out it feeling sticky or sticking to it.I'm sure you can see the difference between wet and dry base coat,remember your base doesn't need to be glossy when dry,a flat appearence is normal.Use base coat tack cloths between coats and wipe good,(not hard) feeling for the little nibs that can form from either static sucking lint from your clothes or just paint falling back down on the surface in little balls kinda-like hail stone form.
oh yea.. tack rag tack rag tack rag... the more time and detail you put into the job the cleaner it will come out.... trust me, i made the mistake of being in a rush
I'm looking forward to paint my car too and what do you mean by tack rag?
