CF Hood Adjustment??
Old Feb 2, 2004 | 12:51 PM
flappy188's Avatar
flappy188
O.G. SON!
Default CF Hood Adjustment??
Ok so i got my fiberimages hood,Really nice,But it fits kinda goofy!
AT first it wouldnt close all the way, so i adjusted my hood latch, upwards! That helped it close tightly. Now the problem is a gap on the passenger side,and the hood is sitting slightly higher then the fenders in some places on both sides. The gap on the passenger side was the size of your pinky fingernail,Sideways, but since i adjusted the latch that seems to be slightly smaller.Its still there tho! but on the drivers side the gap is almost perfect. Help!!!!!!!!!!!!!!!!!!!!! i know some of you guys have had to deal with this. thanks in advance
-Rich
Old Feb 2, 2004 | 02:12 PM
Truxman's Avatar
Truxman
My CF hood is the same way. I tried some adjustments, but couldn't get it perfect. I was happy because it looked a million times better than my old hood with the bowling ball size dent it the hood.
Anyone have hints on how Flappy and I can get these hoods to fit better?
Old Feb 2, 2004 | 04:36 PM
Wharbone's Avatar
Wharbone
This is taken from the Service Manual:
Hood Alignment:
-The hinges can be adjusted right and left as well as fore and aft by using the elongated holes.
-Turn the edge cushions as necessary, to make the hood fit flush with the body at front and side edges.
-Adjust the hood latch to obtain the proper height at the forward edge.
Hope this helps you.
Old Feb 3, 2004 | 07:34 AM
Nelson's Avatar
Nelson
Administrator
That's a common CF hood fitment issue, more so with certain FI hoods. From everything I have gathered, the latch and hinges should definitely be adjusted first. I had actually taken out my latch and extended the holes on the mounting to make the latch go even higher. The only way to really fix the gapp issue is by getting hood pins.
9Y0 Cayenne GTS
E46 ///M3
YD4 MDX
- SOLD
EG Ferio - SOLD
FA Ferio - Returned
www.NelsonLee.net
Old Feb 3, 2004 | 07:43 AM
randomtask77's Avatar
randomtask77
Wanderer
Since were on the issue of carbon fiber hoods, there was a reason why I took mine off. During a certain period when I drive, and I come to a stop at a light, my hood would shake... Vigorously.
Now I don't really know what's causing it, but I do know it might have something to do with the fitment. When it was on the car, the hood was sitting a little closer to the driver side fender (the gap was pretty big on the passenger side) and the passenger side of the hood sat a little higher.
I don't know if the hood's in contact of something that would shake horrendously or it's because of the fact that the hood is so light that it's supposed to shake or I just have a really bad running car. But it is kinda embarassing to be at a stoplight and see my carbon fiber hood shake it like a polaroid picture. You guys have any ideas how to remedy this (I'm guessing pins would be one idea, but I'm looking for other suggestions besides that).
Thanks.
Old Feb 3, 2004 | 07:59 AM
Nelson's Avatar
Nelson
Administrator
Thanks.
Which brand hood do you have? I used to have that problem, but after I installed eyelids, the hood sits more flush and kind of pad's the hood.
You might want to try the rubber seal (that goes on the factory hood) and that might absorb some vibration as well.
9Y0 Cayenne GTS
E46 ///M3
YD4 MDX
- SOLD
EG Ferio - SOLD
FA Ferio - Returned
www.NelsonLee.net
Old Feb 3, 2004 | 08:04 AM
alphaxxn's Avatar
alphaxxn
4500rpm hesitation
I had to adjust my lock, I am using a fiberimages hood as well.
Old Feb 3, 2004 | 08:39 AM
randomtask77
Wanderer
Hmm... Never thought of that. I have a VIS hood, and there are holes for that front rubber seal, but I never bother to transfer it when I put on the hood. Thanks for the idea. I might put the hood back on soon when I get that seal. :goodjob:
s7e
92+ Civic/EL & Del Sol
29
Aug 17, 2003 01:54 PM
DarkSideAccord
Accord
17
Apr 14, 2003 06:57 PM
kfar09
16
Jan 6, 2003 03:38 PM
gritsak
CRX & Pre 92 Civic
13
Oct 12, 2002 06:39 AM
Jeice
8
Aug 12, 2002 07:38 AM
