fuel, spark, no fire?
Old Aug 2, 2006 | 11:05 PM
  #31
PoloBoy's Avatar
PoloBoy
you said you did a engine swap from an h23a to an h22a, did you do the work or did a shop is my first question? did you or the shop do it correctly because you have to have a few coolant hoses that arent ran in the engine bay of the h23a assembly, like on the h22a engine bay, if in deed everything is where it needs to be for the swap to work, than timing is what im pretty sure it is. If you did the timing yourself or with your friend then my guess is the camshafts or cam gears arent timed properly. The very first time I rebuilt my head on my f22b DOHC, I thought I did my timing perfectly except my skunk2 cam gears weren't as easy as the stock gears "in other words they don't have dummy marks on them that are completely obvious and sure enough I found out my timing was off 90 degrees which when I tried to start the engine made me think the same way you are, I thought it was gas, or spark related because the car cranked and cranked sometimes even backfire but never start. Deffinetly get your timing checked by a respectable honda technician I really think thats what it is. unless like stated at the beginning the direct swap wasn't done correctly. goodluck
Old Aug 3, 2006 | 02:52 AM
  #32
jdmhondalude22's Avatar
jdmhondalude22
well first off, nothing with coolant lines is different, the ONLY different thing is vtec wiring in my case just because mine is a 92. the motor ran in my friends car before we took it out.
Old Aug 4, 2006 | 10:15 PM
  #33
Phateless's Avatar
Phateless
S2K compatible
you mentioned it started when you used starting fluid. i'm curious to pursue that idea a little farther. it's either not getting fuel, or not getting the right amount? is anything in the fuel system different from what was being run in your buddy's car?
Old Aug 6, 2006 | 07:56 AM
  #34
jdmhondalude22
hey, thanks for your help guys, injectors where bad. car runs good now, im a little lean but im happy its running.
Old Aug 6, 2006 | 08:07 AM
  #35
Phateless's Avatar
Phateless
S2K compatible
awesome, glad you got it running. now how about some pics??
Old Aug 6, 2006 | 07:53 PM
  #36
vassil3427's Avatar
vassil3427
Thats awesome man! Yeah...I'd read on several swap sites that if the engine sits, its very probably the injectors freeze up...Glad I could help! Now go hit some VTEC...
