Looking For Performance/Stiff Shocks???
Old Apr 27, 2003 | 08:59 PM
Shingoblade-GSR's Avatar
Shingoblade-GSR
Hellsing Agency
Originally posted by taurus90djl14
I was hoping you could explain why your set up did this
If I recall correctly, Winston had his coilover setup installed at a not-so-knowledgeable-place that set the GC's on their lowest setting. Noone drives on the street with off-the-shelf GC's set to the lowest level (4"). To go that low you'll need to custom order shorter springs with higher springrates and mate them with a shorter shock that is valved to handle the higher springrates.
Shingo
Old May 19, 2003 | 08:37 AM
jcd2num1's Avatar
jcd2num1
Default KONI yellows, eibach pro's
i had a prelude with koni yellows and eibach pro kit springs. that was the best setup i've ever driven, but i know the drop on the pro's doesn't seem to be as much. you could push down on the front of the car with that setup and the car wouldn't budge...
Old May 19, 2003 | 09:49 AM
FURIOUSGSR01's Avatar
FURIOUSGSR01
FURIOUSRSX04
Originally posted by stevieteg
Well the sleeve did not sit properly on the bottom perge so the spring rubbed slightly on the shock. Also I had to run my car slammed to the ground, about 5", every time I would go over a bump the spring would bottom out if it were any higher. I ended up getting sportline and I could not be happier. My coilovers were crap though. They worked well woth the stock shocks, but not the performance ones.
You lowered your car 5''???? Well you should have expected your car to behave the way it. Sportlines dont even lower ur car 2''.
Also what is everybody opinion about G/C with illuminas?
Old May 19, 2003 | 10:18 AM
Legend_master's Avatar
Legend_master
Never fast enough member
Well also with a four inch drop you don't have much room for movment int he shock area and so the luminas made the ride stiff. All that had to be done to fix this was raise the car. I have R1 racing coilovers with tokico blues and it rides great not to bouncy at all. My old car had tockios in the fornt and kyb's in the back and the kyb always made the tires rub because they were not stiff enough.
P.S. they did not make tokicos for the rear of my old car so that's why I mixed.
