GS-R performance..............
Originally posted by ur31337
I've driven 3 GSRs as of late, I wouldn't fixate on 2nd gear too much. It's not really as big a deal as you're making it out to be.
Spend more time with the car, learn to work around the issue you're having. Why waste money on it?
Originally posted by reno96teg
apples and oranges, my friend...
of course a fast shift will result in revs being pulled down, it doesn't matter how close the gear ratios are, unless they're identical (which would be pointless), this will happen. duh![/B]
What happened?? Revs fell in the time it took to clutch.... identical ratio. :fawk:
you waste soo much time in a shift if you're waiting for the revs to fall so that they'll match.
this little argument of yours further enforces my statement that you need to learn to shift better.
Honestly... there's different ways to skin a cat, you pick yours. I'll stick to blaming the cat.
Originally posted by stumpyf4
Yes I work around the problem in daily driving however when I want to get the hell "out of dodge" that 1st to 2nd shift annoys me. Simply put the ITR has a better ratio.
If you could deal with the high revs, I'd get a JDM ITR tranny. If not, an ITR swap would be worth it, for the LSD.
Originally posted by TriDawg
Ive also driven all makes in models of porsche's and even a Ferrari and honestly if you KNOW your vehicle.. Especially the GSR in this case.. you wouldn’t be complaining about such a minute difference.
The car has SOOO much potential. Why waste your time with a gear when you can throw on a CAI and make up for the split second of (supposable) engine lag between shifts ..
.. Cause I know with my 7k mile GSR, I dont run into issue's shifting @ 8k and noticing a lag to second.
[B]Im not doughting its not there
its just not that much of a problem to worry about that would require money to switch out when you can be doing so much more with so much less $$$ fronted.
Very true, it's a bit easier in my car than Chad's (Tridawg). I would imagine you could just get an ITR 2nd gear, but that's a lot of work for so little. Throw in a Quaiffe while you're at it. :naughty:
I wasnt showing sign of weakness I just didnt want to be an ass .. but since you opened the door.
I think your a DUMBASS for worrying about such a minute problem. How F*cking Anal retentive does one have to be. OMG my second gear ratio is a tad longer then it should be. Im going to go out of my way to buy a ITR tranny. Why dont you just buy an ITR in the first place and skip the hassel? The GSR was made the way it was for a reason.. and when I was talking about the CAI and its infulence on the car I wasnt talking about it shorting up the gear ratio .. I was stating that 7more HP to the wheels might be enough where the drop wouldnt be as noticable...
So at that I leave you to dicking around with you GSR to make it something its not. Ill be content with what I bought and know that theres more to life then my ride ...
Peace
-Tri
Peace
-Tri
