Subframe Tearout
Old Jun 4, 2006 | 06:06 PM
kartman2's Avatar
kartman2
Default repair
The other dave was right. You'll need to take out the entire rear suspension and have it repaired with a new plate and weld. As a
former BMW owner I'm very familiar with this type of problem. They
weld a reinforsement plate over the defect. In the right hands it will
be better than new. Good luck.
Old Jun 4, 2006 | 06:10 PM
94civicEX's Avatar
94civicEX
I got worms.
Yea I talked with the engineer over at Comptech and he'd like to see the cracks welded and a reenforcement plate made of 1020 Steel welded in as well.
99 Integra GSR
06 TSX
duck squad member #00003
Old Jun 5, 2006 | 08:22 PM
n0va's Avatar
n0va
I was wondering where you can pickup one of those asr braces. Thanks.
nOva
Old Jun 6, 2006 | 09:25 PM
94civicEX's Avatar
94civicEX
I got worms.
nOva
www.passwordjdm.com
or
http://a-spec-racing.com/
99 Integra GSR
06 TSX
Old Jun 6, 2006 | 11:13 PM
sirg-vtec's Avatar
sirg-vtec
I just wanted to fit in.
From the information that I have gathered. A subframe tearout will indefinitely happen when using a larger swaybar. When will it happen you ask? Right now, maybe tomrrrow, a couple of years, or a decade from today. Just like a tootsie pop, "The world may never know." With the ASR/Comptech brace, it will only prolong the inevitable. A stiffer spring rate will also add days, months or even years to the life of the subframe. Thus, the driving condition will effect the subframe tremendously. As stated, he heard a pop going at a forty-five degree angle up a driveway. As you will figure out, this will put a tremdous load on the subframe. Pot holes, speed bumps, and any other anti-speeding obsticles will contribute to the tear-out. There is no other way to be safe but there is a way to be prepared. Reinforce the subframe with either an ASR or a comptech kit. Stiffer spring rates will help. Put some money away for a rainy day. And good luck.
Old Jun 7, 2006 | 01:15 PM
94civicEX's Avatar
94civicEX
I got worms.
Yea I already have changed my driving style. Instead of angling all wheels I only angle the front wheels then bring the rears as parallel as possible.
Maybe I should fix it up, get the asr brace and stock sway bar and call it a day.
99 Integra GSR
06 TSX
