Subframe Tearout
Old May 29, 2006 | 11:47 AM
TheOtherDave™'s Avatar
TheOtherDave™
Apathy Kills
Originally Posted by [Damnit]
what would happen if you drove around like this?
With the sway bar still installed, the rips would continue to enlarge.
Eventually, the damage would threaten the structural integrity of the rear suspension mounts. It is an issue requires prompt action to repair.
I'm quite surprised that the Comptech bar did this. IMO, it illustrates the need for some sort of reinforcement when runnning any aftermarket sway bar. :hs:
Old May 30, 2006 | 11:34 AM
94civicEX's Avatar
94civicEX
I got worms.
Hopefully I can have it seam welded. Afterwards I'm going to look into getting this:
99 Integra GSR
06 TSX
duck squad member #00003
Old May 31, 2006 | 03:31 PM
94blueteg's Avatar
94blueteg
screwed
whats a set up like that cost?
Old May 31, 2006 | 05:47 PM
94civicEX's Avatar
94civicEX
I got worms.
I talked with an Engineer at Comptech today. He said if I find a good welder it can be patched up for sure.
I've also talked with the guy that engineered the ASR Brace and he suggests the same.
So I've got to get it to the welder now.
99 Integra GSR
06 TSX
Old May 31, 2006 | 06:58 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
Originally Posted by Däs Schmoo
What kind of springs/shocks do you have?
Just curious to see if there could be any corelation?
Old May 31, 2006 | 11:38 PM
94civicEX's Avatar
94civicEX
I got worms.
Comptech Sport Springs with Koni Yellows.
99 Integra GSR
06 TSX
Old Jun 1, 2006 | 09:04 AM
bnuk's Avatar
bnuk
yeah springs will have a huge effect on the likely hood of this happening. I put my ITR sway bar on a week before i upgraded the srpings but i didn't hook up one of the endlinks until I had the stiffer springs.
Old Jun 1, 2006 | 09:28 AM
Provocateur
On permanent hiatus
Would stiffer springs have this more likely to happen or softer springs? I have GC's 350F, 450R going in this weekend and a tearout worries me. I will double check the tightness of everything when I install the springs, but I just want to make sure I am not at risk for tearout with my Comptech sway bar.
Old Jun 1, 2006 | 06:41 PM
bnuk's Avatar
bnuk
stiffer springs will help a lot, We've more than doubled our rear rates so that means that for the same bumps the wheel is going to move a lot less (relative to the car).
you guys almost jinxed me today, they tore up the pavement on this one stretch except for the manholes, which now stick up like 3-4 inches. I was following a truck and didn't see one of them and i hit it with the left side going like 35, the back end made made a weird croak noise and kinda hopped a little to the side. I looked over it really close and luckily it looked ok.
Old Jun 4, 2006 | 02:59 PM
94civicEX's Avatar
94civicEX
I got worms.
Yes, stiffer rear springs help the problem, but only makes it less likely to happen.
Well I pulled off the bar, so at least I can drive it.
So what happened was it tore out the welded nut, then the bar wanted to get pulled down, it couldn't so it started to tear it from the top and buckle at the bottom.
Here is the only pic that came out, I have to raise it up again:
99 Integra GSR
06 TSX
