i just got an idea
Originally Posted by JoePannone
oh alrighty, thanks for the info everyone
ill just buy another LS long block. should i buy the block guard for that or would i be ok with running 4-6 psi daily. oh and this wont be happening for a while so im just figuring out my plan of attack first.
The b20 can still handle boost. It's a common misconception that they have weak sleeves. I've seen people running 15+ PSI on stock sleeves. It's all in the tuning.
i also have the stragest idea that the better r/s ratio will allow the engine to live longer....
Originally Posted by sherwood
i still want to see a b16 turbo in one of these cars, .. it's different seeing a smaller than stock engine pull harder and better than a/the larger engine.
Well a B20/LS/GSR turbo would pull harder than the B16. As for the r/s ratio, it'll handle high rpm a little better, but the others will last just as long. Built correctly, and they'll handle boost and high rpm no problem.
h:
Originally Posted by Shmoo
And toasting a B16 with a bored and sleeved 2.0L GSR motor is even cooler.
h:
h:Torque is fun. Enough torque to spin the tires in 4th gear on the freeway is even more fun.
im not going to be building the motor or anything, i just want to have a little more get-up-and-go power and still stay reliable. this is a daily driver so im not going to be running a lot of boost on the motor (4-6 psi). so which would be the better motor for my purpose?
I'd go B20 if it was me.
