i just got an idea
Old Aug 4, 2005 | 03:37 PM
JoePoonani's Avatar
JoePoonani
Lexus Tech y0!!
Originally Posted by sherwood
i'd say run 8 psi on a c1 if possible for reliability and performance purposes
reading > you h:
so how would the B20 hold up with about 4-6 psi totally stock internally? and would the B20 out of a CRV be easy to swap into the teg?
Old Aug 4, 2005 | 04:14 PM
dubcac's Avatar
dubcac
I
Like i said before, it would be fine. It's just like putting an LS motor into an integra. Use the LS harness, ECU, intake manifold, clutch, flywheel, tranny, mounts. It's the same exact motor externally, except for the intake manifold.
Old Aug 4, 2005 | 09:43 PM
JoePoonani's Avatar
JoePoonani
Lexus Tech y0!!
would i have any problems if i happen to buy an OBD2 motor? would i be able to use all my OBD1 hardware?
Old Aug 4, 2005 | 10:45 PM
Elborintegra's Avatar
Elborintegra
yep.. you'd be ok... I was using OBD-0 hardware in mine...
suggestion for the b20... try to get the B20Z... and even better would be a P8R head.
Old Aug 4, 2005 | 11:32 PM
dubcac's Avatar
dubcac
I
I have a P8R head sitting in my garage. And yes, the B20Z is better, or the 99-00 B20Z...higher compression, more power. As for the OBD2 motor, you'd be fine putting it into your car. Just use your OBD1 distributor and ECU.
Old Aug 5, 2005 | 09:45 AM
sirg-vtec's Avatar
sirg-vtec
I just wanted to fit in.
Originally Posted by JoePannone
im not going to be building the motor or anything, i just want to have a little more get-up-and-go power and still stay reliable. this is a daily driver so im not going to be running a lot of boost on the motor (4-6 psi). so which would be the better motor for my purpose?
then stay away from turbo. I know its cool to have an intercooler and when you car go pshhhhh but if you want something for reliability, why not just swap in a b18c1 or c5? It'll last you another 100K+ miles with a little more hp than the b18b.
Old Aug 5, 2005 | 10:11 AM
MathGSR's Avatar
MathGSR
You'll run 4-6 psi for a month, then you'll want more and more and more and more..... All forged... 25 psi! 450 whp....
Old Aug 5, 2005 | 01:41 PM
JoePoonani's Avatar
JoePoonani
Lexus Tech y0!!
like i said, no vtec. :slap: read first post
so would i be safe running 4-6 psi on the B20 daily with some tuning?
Old Aug 5, 2005 | 04:19 PM
dubcac's Avatar
dubcac
I
Learn how to read.
Old Aug 5, 2005 | 08:43 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
I am running 8 psi daily driven on my GSR motor with 138k miles with little to no downtime. I am failing to see your point.
