new to integra - advice & basic questions
Old Aug 31, 2004 | 11:38 AM
Tobra's Avatar
Tobra
Just because it is not to 100,000 kms yet does not mean the timing belt is in good shape, I would change it, old and rubber is not a good combo
Old Aug 31, 2004 | 02:17 PM
Cure3's Avatar
Cure3
pixelassassin.net
Replacing the stock HU is a pain. Basiclly you need to take out the glove compartment, remove the center console, then remove the side panels on both sides of the HU. There are two screws in the back of the HU holding it in, you gotta take out those screws and slip the HU out.
At least this is how I did, I think you could reach the screws without removing anything but it would be difficult.
Speakers are easy, there are three screws on the door panel (one is plastic with a plug). Undo those and lift up on the door panel and boom. Make sure you disconnect the power connectors for the mirror, window and door locks.
The back grate panel should come right off for the rear's but to take the rear side panel you gotta start in the trunk and undo all the screws. There is two bolts and another two plastic screws I believe.
Replacing the speakers was a bit tricky cause they required a plastic spacer ring. My Apline type-s' came with the ring but I hear they are the only aftermarket speakers that do. Both the front and rear speakers are 6.5". Hope that helps.
Old Aug 31, 2004 | 08:05 PM
tams's Avatar
tams
thanks for all your help. the new h/u is in and working well, now just need to get new speakers. had to take the whole dash apart to figure it out but the screws can be reached if you know where to look. luckily for us, as i wired it incorrectly. lol. really need to find myself a manual.
any suggestions on speakers for the doors? to go with pioneer h/u.
Old Aug 31, 2004 | 10:03 PM
Kai's Avatar
Kai
Rotorphile.
I didn't have to take my glove compartment out.
What the hell are you talking about? You don't have to take the door panels off to change the speakers.
Old Aug 31, 2004 | 10:57 PM
Cure3's Avatar
Cure3
pixelassassin.net
I said in my post you probably wouldn't have to take anything off if you can reach in the back. I just suggested taking anything out that would make it easier.
And how do you replace the front speakers with out taking the door panel off?
As far as suggesting speakers, I love mine. I prefer Alpine to Rockford and would have gotten Alpine type-r dual voice coil subs if they weren't so darn expensive. All my audio is in my sig.
If you want to find out what you like go to a car audio place and play around. They should have a board that lets you test different system set ups.
Old Aug 31, 2004 | 11:01 PM
g2tegls's Avatar
g2tegls
MR, ftw
I think if you take off the speaker cover you have access to the screws.
Old Aug 31, 2004 | 11:03 PM
Cure3's Avatar
Cure3
pixelassassin.net
Even if you did the spacer wouldn't fit through the hole.
Anyways, whatever works, I like to have full access to everything so I don't have to work in such confined spaces, so I take it all apart.
Old Aug 31, 2004 | 11:17 PM
Kai's Avatar
Kai
Rotorphile.
You just pop off the plastic grill over the speaker.
I never needed to use spacers in my old G2, most speakers don't need them.
Old Sep 1, 2004 | 05:05 AM
bluetwo's Avatar
bluetwo
Relevance is irrelevant
You can do it.
Old Sep 1, 2004 | 11:46 AM
Cure3's Avatar
Cure3
pixelassassin.net
Well the spacer was necessary for the type-s'. Even with it they touch the back of the well.
