engine swap
Old Aug 31, 2004 | 11:23 AM
spumonisteg91's Avatar
spumonisteg91
Default engine swap
can i swap a Type R engine with a 91 integra RS B16A1. and would i be able to switch and use the type R center counoles and gauges on my 91 integra.
Old Aug 31, 2004 | 11:36 AM
Tobra's Avatar
Tobra
Engine yes, but you'd have a problem with the transmission. The gauges and console would have to be rigged up to fit, why, you got a line on a wrecked ITR?
Old Aug 31, 2004 | 12:25 PM
spumonisteg91
why would the tranny be a problem
Old Aug 31, 2004 | 12:28 PM
spumonisteg91
"why, you got a line on a wrecked ITR?"
no i was jus thinkin about swaping a type R for my motor of line and makin my interior sorta like the type R
Old Aug 31, 2004 | 12:56 PM
92eg6's Avatar
92eg6
99 CG3 Owner
because the type-r tranny is hydro, and your car is cable clutch. you can get a hasport conversion kit, but it will cost you a couple hundred bucks.
Old Aug 31, 2004 | 03:08 PM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
This should be what you'd need: http://hasport.com/shop/product_info...products_id=95
Old Aug 31, 2004 | 06:24 PM
spumonisteg91
thanx alot guys
Old Aug 31, 2004 | 09:06 PM
Kai's Avatar
Kai
Rotorphile.
The easy way around it is to get just a B18C5 longblock and swap on your B16A trans, distributor, harness, injectors, etc.
I see you haven't read Dan Platt's G2 swap guide. Read it now, ask questions later.
http://www.g2ic.com/tegtips/engine/E...Swap_Guide.doc
Old Sep 1, 2004 | 02:44 PM
spumonisteg91
thanx this really helps
