timing belt
Old May 13, 2004 | 11:30 PM
sstearns2's Avatar
sstearns2
My 2000 GS-R owners manual states 105K miles for the timing belt. Did they change something in the engine on the newer cars or just change the number in the book?
Scott
Old May 14, 2004 | 09:14 AM
HYBRID's Avatar
HYBRID
Originally Posted by HYBRID
im glad you see it my way thanks alot everyone
oh by the way one more question, my clutch is leaking by the pedal my carpet has stains and pedal is wet. what is the culprit is it the master or is it most likely a seal?
Old May 14, 2004 | 09:23 AM
TheOtherDave™'s Avatar
TheOtherDave™
Apathy Kills
Well, presuming the fluid is indeed clutch fluid, then your master cylinder has probably sprung a leak, or perhaps the seal on the piston is wearing out. If the fluid is leaking directly from the master cylinder, your best bet is to replace the master cylinder outright, as a unit IMO.
Old May 14, 2004 | 10:12 AM
HYBRID's Avatar
HYBRID
well i know its clutch fluid because the fluid disappeared from the reservoir and i had to fill it up again. thats the thing i cant see whether its directly the master or not. is there a way to check?
Old May 14, 2004 | 12:51 PM
LT's Avatar
LT
The deer had to die!
cant you do a pressure check of the clutch master cylinder to find leaks? what if it was the seal on the piston...how difficult would it be to replace?
Old May 14, 2004 | 06:57 PM
Amirked's Avatar
Amirked
OHHH GREAT TOPIC! I'm just looking right now at getting my timing belt done (92k) - i called the dealer .. for a T-belt, new drive belts, and a water pump the want $780!!! - I called around and I found a place that will do it all for 220 labor .. then whatever the cost of parts (its marked as a 3 hour job). . anyway so somewhere inbetween there should be decent.
I also have a leak coming from the clutch pedal .. my clutch fluid is dark brown and i think it means my seals are shot .. i have a helms manual - How easy is it to put a new master cylinder in? Also - if my clutch master cylinder has a leak .. would that make my clutch pedal feel really loose? or is my clutch actually going out? It never slips out of gear but the pedal is really easy to push in/out and it can come out almost all the way before it starts to transfer power.
Sorry about the long post .. please let me know what you find out
Old May 14, 2004 | 07:21 PM
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
Yeah, a leaky clutch master cylinder would indeed make the pedal feel loose.
Old May 14, 2004 | 07:50 PM
Amirked's Avatar
Amirked
awesome .. well not awesome but a hellevah lot better than putting a clutch in. . i checked on team integra.net and it looks as if this is a common problem. I'm gonna go pick up a master and slave cylinder from the dealer and slap on in .. people said it should be pretty easy and i have a helms .. i think i can work through it .. (timing belt on the other hand is going in). . thanks
petrv
Prelude
10
Mar 17, 2004 07:50 PM
petrv
Engine Swaps, Tech & Tuning
Mar 1, 2004 03:30 PM
JiggaFan
4
Feb 22, 2003 08:55 PM
