throwing a code 14, EACV. help
i have a 91 hatch with a 91 ls motor and ecu. The ecu is flashing code 14 which is the one for the electronic air control valve. This does make sense cause the car won't idle and it kinda bounces, how do i fix this? Is the valve bad or what.
Yeah like JimBlake said, the three possible causes of a Code 14 are the valve has gone bad, it's unplugged, or there's a wiring issue. As long as the thing is plugged in you most likely just have a bad valve.
well...it could be a wiring situation. i swapped the motor and i had to splice in the plug for the integra cause my civic plug did not fit. It was only two wires though, and i've tried wiring it both ways. How much is this to replace?
damn. that's spendy. How would i figure out if the wiring is messed up with a voltage meter? This was my first swap and i really learned everything i've done from this site, so i'm a little stuck right now and unexperienced. Thanks for all the help
Maybe?? A vacuum leak or somthing else that screws up the idle speed. The ECM uses the IACV, trying to control the idle. It doesn't work because of the vacuum leak, but the ECM doesn't know why - so it blames the ICAV.
DVPGSR
92+ Civic/EL & Del Sol
17
Jul 12, 2003 05:49 PM
DVPGSR
Engine Swaps, Tech & Tuning
Jul 12, 2003 12:15 PM
AwwsChwA
Jun 6, 2003 07:48 PM
crucial Si
28
Aug 10, 2002 09:03 PM
