throwing a code....cant find where to jump it.
Old Aug 9, 2002 | 09:02 PM
crucial Si's Avatar
crucial Si
Banned
Default throwing a code....cant find where to jump it.
i have a 92 si and i cant see where i need to jump it to see what code i am throwing. any help please, thanks
Old Aug 9, 2002 | 09:15 PM
Jkan2001's Avatar
Jkan2001
S2000 Pilot
Default Re: throwing a code....cant find where to jump it.
Try www.jdmfan.com. There is a whole section about checking the code by using a paperclip, watching the blinks, and then a chart will tell you the code by how many long/short blinks you saw.
Old Aug 9, 2002 | 09:19 PM
crucial Si's Avatar
crucial Si
Banned
yeah but i dont know where to jump it using the paperclip.
Old Aug 9, 2002 | 09:20 PM
Fujiwara Takumi's Avatar
Fujiwara Takumi
It's my first day.
its a little wire socket protected by a piece of green rubber underneath your glove compt, behind the kick panel.
Jkan2001's Avatar
Jkan2001
S2000 Pilot
just go read it...there is some sort of green harness i think and you make a U out of the paperclip and stick one end in the one of the clip holes and the other end in another clip hole....at least that's what i remember. it will tell you how to do everything
Old Aug 9, 2002 | 09:31 PM
Fujiwara Takumi
It's my first day.
it certainly isn't brain surgery.
Old Aug 9, 2002 | 09:32 PM
Jkan2001's Avatar
Jkan2001
S2000 Pilot
i would certainly hope so....if it was there would be a lot of dead riceboys out there
Old Aug 9, 2002 | 09:36 PM
crucial Si's Avatar
crucial Si
Banned
yeah i found it..was way up there..anyhow
code 22...
22 VTEC Oil Pressure Switch Open or short in VTEC OPS circuit, defective VTEC pressure switch
WTF does this mean and what do i need to do?
Old Aug 9, 2002 | 09:38 PM
Jkan2001's Avatar
Jkan2001
S2000 Pilot
code 22...
hrmm...if it was the defective vtec pressure switch i would guess your vtec solenoid is having problems and isn't engaging when you hit the proper rpms. As for the first one i have no idea...call the dealership up.
crucial Si's Avatar
crucial Si
Banned
the light kicked on after i turned down the timing alittle bit.
