did i install the neuspeed koni sp3's correctly?
hey reno do i have the spring perches on upside down please help me, is there anything on than the top part of th e stock shocks i have to reuse, o rings please help
im in vallejo california any cheap shops
ok we got the fronts on correctly, now all we have left is to replace the rear shocks, is it going to be easier guys, i heard bad stuff about the lca bolt, do i need a compressor i have neuspeed race springs, just replacing the shocks with koni yellows sp3's, please help guys
My Helms manual sure does think you need a spring compressor.
https://www.honda-acura.net/forums/s...d.php?t=129685
Originally Posted by WiLL
no you do not need a spring compressor. i suggest you make those dust boots fit. they are there for a reason.
i got koni yellows on 4 door gsr with neuspeed race springs, how did you guys adjust rear 6:03 PM 4/1/2004 Reply Edit
hey guys is it better for me to adjust to full stiff then full soft, i dont care about comfortability, is it better to be a t full stiff so that the springs dont hit the bumpstop a lot
Rebound is the resistance to the shock "Rebounding" or expanding back out, to accomodate for bumps. Therefore on full rebound the shock rebounds slower.. For street use, you want it to rebound faster to accomodate for bumps etc.
soo, you would want it on full soft.
If you autox etc. you would want to set the rears to full stiff (rebound) and the fronts to most likely 1/2 stiff (rebound.) But, that takes some testing etc.
