did i install the neuspeed koni sp3's correctly?
Originally Posted by greengsr2k
i set the spring perch on the lowest one it was set normal before and i change it to the lowest setting lowest height
it does not fit on the metal rod on the koni yellow shocks, hey will please help i installed my koni yellows wrong, do you have installation instructions for koni yellows,the koni instructions suck please help me
i live in the bay area, you know any shops that would install my koni yellows real good for a good price
tell us what problems you are having.
i need better instructions to install myself,and will you know the brake line bracket on the old shocks, the koni yellows doest have it do i need those brackets on koni yellows
is the perch on the pic correct way up not upside down
according to reno on this board....you have to hammer the hold bracket out carefully. then use it on the konis.
and im not too sure about the perch being upside down. how does the spring sit on it?
what city are you in, btw.
Originally Posted by WiLL
if it does not fit the metal rod, i would expand the hole on the dust boot to make it fit.
