92 GS-R fluctuating idle
Old Mar 9, 2004 | 08:08 AM
Thunder's Avatar
Thunder
Default 92 GS-R fluctuating idle
Hello Friends,
I bought a 92 GS-R last week. Has a few things to fix, but the pressing issue is the fluctuating idle. It bounces between 2000 RPMs and 750 RPMs. Sometimes it stalls out. I replaced the fuel pump, and swapped out 2 MAP sensors, but it still fluctuates. No codes on ECM. Previous owner says that it would stall out when it got to a half tank.
How do I get the idle under control?
Thunder
Old Mar 9, 2004 | 09:35 AM
intgrboy's Avatar
intgrboy
oxygen sensor maybe?
Your problem seems worse than mine but to resolve mine i had the whole engine flushed of all the carbon deposits
Old Mar 9, 2004 | 09:43 AM
94civicEX's Avatar
94civicEX
I got worms.
Take off the intake, their will be a hole in the throttle body for your IACV (idle air control valve), plug this hole with your finger with the MAP sensor unhooked and the car idling. If the car stalls, it is your IACV, if it doesn't, it's a vacuum leak somewhere else.
99 Integra GSR
06 TSX
duck squad member #00003
Old Mar 10, 2004 | 11:36 AM
hondatech's Avatar
hondatech
Honda tech/eprom hackr
whoa, just adjust the cold air idle valve first. Taking the whole intake off first is overkill. not to mention a pain in the ass. You should make sure u have a full amount of coolant.
If you're gonna shotgun parts, can I have the old ones???
Old Mar 10, 2004 | 12:39 PM
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
When does the idle bounce? Does it happen when the engine is cold, the engine has warmed up, or both?
Old Mar 10, 2004 | 12:50 PM
DB7 2.0's Avatar
DB7 2.0
Banned
definitely check the idle control valve first. easiest to check too.
Old Mar 10, 2004 | 04:19 PM
bball15133's Avatar
bball15133
Try bleeding the coolant system valve. We did this on one of our g2's and it fxed the fluctuating idle.
Old Mar 10, 2004 | 05:42 PM
hondatech's Avatar
hondatech
yeah, bball has the right idea.. OR it's the cold air idle valve. This is a problem that most early 90's hondas/acuras share. I should get some digital pics on how to check and adjust it. maybe put it in that other part of the forum.
Old Mar 10, 2004 | 09:35 PM
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
Here's the idle troubleshooting guide from my Helms manual.
One problem that people sometimes have is the IACV goes bad without throwing a code so there's no real way to check if it works in the Helms.
I've also attatched the pages on how to set the idle speed with the adjusting screw and how to check if the fast idle thermo valve is working properly.
File Type: gif
File Type: jpg
File Type: jpg
File Type: gif
Driver
2
Mar 6, 2004 06:44 PM
bizkit
Accord
7
Feb 4, 2004 10:52 AM
AwwsChwA
Engine Swaps, Tech & Tuning
4
Oct 10, 2002 06:17 PM
MoFo
7
Aug 31, 2002 11:14 AM
Outxider
92+ Civic/EL & Del Sol
4
Aug 27, 2002 08:16 AM
