Problem changing my axles...
Old Mar 13, 2004 | 08:52 AM
alnen's Avatar
alnen
Default Problem changing my axles...
That stupid spindle nut is destroying my arsenal of wrenches. The notch was bent out, and I don't know what the problem is. I just sprayed some penetrating stuff on to loosen it. Am I missing something? the car is on the ground still, but it is just really hard to turn. Which direction should it be turning in to loosen? Thanks, I need this info ASAP.
Old Mar 13, 2004 | 09:01 AM
rgbpmp's Avatar
rgbpmp
turns counter clockwise to loosen. make sure the bent part is bent back out and pretty round. Get a breaker bar. Or a good ratchet and put a bar on the end to extend the ratchet. maybe step on the bar if you still cant get it off.
Old Mar 13, 2004 | 09:03 AM
Daniel's Avatar
Daniel
Or use an impact wrench. That is the only way I tackle that axle nut.
Old Mar 13, 2004 | 03:01 PM
integraclownnu's Avatar
integraclownnu
Get a good quality breaker bar and socket. Slip a 6' pipe over that and stand on it. It takes quite a force! Or if you have access to air pressure and an impact, definately go that route. I love IR impacts
Old Mar 13, 2004 | 03:10 PM
Sam92teg's Avatar
Sam92teg
I have replaced both my axles and my trusty 1/2 breaker bar and socket did the job nicely, I did have to put a foot to it tho. I would like to invest in an electric impact wrench one day if I can find one with alot of torque.
Old Mar 13, 2004 | 03:14 PM
integraclownnu
Buy a milwaukee, but I recommend an impact powered by air pressure. Charging batteries is a pain!! Congrats on getting the axles changed.
Old Mar 13, 2004 | 06:18 PM
alnen's Avatar
alnen
Thanks guys! It's done now. I used a breaker bar and the pipe from the jackstand and it came off. I also sprayed some of that peneterating sheot on there, I guess that might have helped some. I appreciate it!
Old Mar 14, 2004 | 12:45 PM
TheRooster's Avatar
TheRooster
Former Senior Member
Aerokreoil is your friend for rusted on bolts and nuts. I used about ten-foot of cheater and broke my breaker bar in half before realizing that I didn't punch the tab out all the way. D'oh!
puffy
7
Apr 12, 2003 06:06 AM
aero3685
Accord
7
Feb 24, 2003 05:37 AM
SiR-DC2
Dec 10, 2002 06:32 PM
acuraocd
3
Aug 29, 2002 02:54 AM
Chookie
2
Aug 14, 2002 08:04 AM
