major problem with axles.. help><><><><
Old Aug 26, 2002 | 11:09 PM
acuraocd's Avatar
acuraocd
Default major problem with axles.. help><><><><
91 Acura Integra
[IMG][/IMG]
My car has been off the road for like 3 weeks cause the state of NH has gotten almost $2500 in tickets this summer..... so i had to put a stock exuast on and raise the car.... when i did this my CV joints shot to h*ll....... so now i have to change them and i have broken 3 braker bars and 1 rachet (half inch drives)..... i can not get the center nut (32mm) off the end off the axle shaft..... i have put so much force of the braker bar that the tire turns while sitting on the ground........ i pounded the staker thing out..... so i definetly know that i am doing something wrong........ how do i go about getting this nut off....... i know that a impact wrench would work.... is there a tool that could help me out...
thanks
http://www.cardomain.com/member_page...cura%20Integra
Old Aug 27, 2002 | 11:30 AM
pomansouth's Avatar
pomansouth
what you do now is find a friend with a air tank or something of that nature and buy a really cheap impact wrench for like 20 dollars and but a impact socket in the 32 mm size and you go to autozone and get some pb blaster and spray a tub of that in something that can be put on the nut all night to penetrate in it well and then try with an impact wrench but if it doesnt come off then well then you gots a real prob and if you want you can try jarring it loose by tapping with a hammer after you soak it in oil
Old Aug 28, 2002 | 09:16 PM
taz77's Avatar
taz77
is there a cotter pin through the spindle nut?
Old Aug 29, 2002 | 02:54 AM
SilverRsx's Avatar
SilverRsx
Use a breaker bar with a cheater bar on top of it. The longer the cheater bar the better, mine is atleast 45inches. Leave the wheel on the car and dont jack it up yet. Have someone step on the brakes and you then turn the sucker off. If that doesnt work just take of the whole hub/knuckle assembly along with the axle off and take down to your local mechanic shop and have them bust it off with an impact wrench for you.
JdM_RaCeR
CRX & Pre 92 Civic
Aug 15, 2006 02:15 PM
retroshark
Accord
7
Nov 29, 2005 12:23 AM
knight akkord
Accord
12
Mar 7, 2004 10:53 PM
JunM
CRX & Pre 92 Civic
4
Dec 13, 2003 02:45 PM
RatedX
4
Feb 19, 2003 06:45 PM
