Integra throttle body
Old Mar 7, 2004 | 05:36 PM
Temple's Avatar
Temple
Default Integra throttle body
Just curious if I can put a GSR etc throttle body on my GS? I just figured out that my check engine light was for my TPS sensor which is riveted to the throttle body, and so my manual says I have to get a new throttle body. Will a larger one be able to work with my ECM or does it even matter? Thanks, any help would be appreciated.
Old Mar 9, 2004 | 08:53 PM
qtiger's Avatar
qtiger
Yes. You could also drill out those rivets and replace the sensor if you're feeling adventurous.
Old Mar 12, 2004 | 06:16 PM
Temple's Avatar
Temple
Isn't the GSR one a larger bore? The sensor on it would still work for my car?
Old Mar 12, 2004 | 10:18 PM
qtiger's Avatar
qtiger
Yes.
Yes.
Old Mar 13, 2004 | 12:51 PM
Temple's Avatar
Temple
Thanks man, much appreciation.
Old Mar 14, 2004 | 12:49 PM
TheRooster's Avatar
TheRooster
Former Senior Member
It'll work, but you might have to get a GS-R cable and bracket. Try it on your setup first, but if it doesn't quit fit right, those will do it for you.
If there's a money issue, then a used GS-R is a good choice. Aftermarket TB's are generally cheaper though if you plan on buying on new. Just a thought.
1fastercrx
CRX & Pre 92 Civic
Jul 28, 2003 07:54 AM
TimeRacer
Feb 12, 2003 04:14 AM
JDM_SiR
Dec 19, 2002 05:33 AM
eclipse spanker
4
Oct 17, 2002 10:42 AM
