vehicle speed sensor help
Old Jul 10, 2002 | 10:52 AM
98EX's Avatar
98EX
Insane Wierdo
Check to make sure you have enough tranny fluid in the car, don't ask me why or how, but mine was doing the same yours was, would work only when it got kinda hot, I drained tranny fluid and readded and it started working like new. Remember when filling tranny on a 5 speed you have to have all 4 wheels off the ground in order to get the righ amt of fluid in there.
Old Jul 10, 2002 | 09:54 PM
maxrpm's Avatar
maxrpm
i tought about that but when i checked it the car was on flat surface and fluid was coming out. I added 2qt and a half. So , i thought it wasn't it. I will go and buy some fluid and try it over the weekend.
Old Jul 11, 2002 | 07:43 AM
98EX's Avatar
98EX
Insane Wierdo
If you want that extra bit of fluid, when you fill it, lower the front of the car lower than the rear, this will allow a little extra bit of fluid in the tranny.
Old Jul 15, 2002 | 09:32 AM
maxrpm's Avatar
maxrpm
i final filled the transmission full and the vss is still jumping around. I also checked to see if the wires were ground and they seemed ok.
Old May 22, 2007 | 03:26 PM
babybluecivic96's Avatar
babybluecivic96
I am having this exact same problem did u find out what it was???????????????????? PLEASE HELP ME!!!!!!!!
Old May 23, 2007 | 08:09 AM
primetime's Avatar
primetime
you should start a new thread, but anyway you may need to change the VSS.
Old Jun 7, 2007 | 04:04 PM
fucuzza's Avatar
fucuzza
I know this has thread has been idle for a while. Just in case you haven't fixed the problem yet here goes. Your descriptions of testing wires are very vague. Sensor is probably 3 wires. 5 volt sensor feed, Signal wire to ecu, ground. should only have power to one wire and it should be 5 volts. The most common problem after swap is gound. Check them close
jdmeg6hatchy
Sep 7, 2005 09:13 AM
silverstreakin
Engine Swaps, Tech & Tuning
4
Feb 20, 2003 01:09 PM
djmtsu
Accord
10
Feb 13, 2003 11:58 AM
jason94accord
Accord
5
Jul 15, 2002 11:00 AM
