vehicle speed sensor help
I haven't switched out the vss with my friend but while i was driving my speed meter started to move up and down like crazy.It won't stay at a constant speed it would go from 20 mph to 50mph at the same rpm. After awhile it would die and stay at zero.
the fuse isn't dead because sometime when it gets hot the speed would kind of work. It will stay constat but when you downshift it will jump up and down, after that it just dies again. Would it have to do with me not putting the axle correctly in? If the axle isn't spinning the gears to the vss or something. My friend couldn't find his extra vss.
