"building" an engine
Old Dec 26, 2002 | 07:49 PM
  #31
livelyjay's Avatar
livelyjay
Ok, I've been on vacation for Christmas and I am glad to see my thread is still alive. I do, however, need a vocabulary lesson since I am a noob to this engine stuff and my huge manual is back in Rochester. Please define and clarify the following terms:
Originally posted by 1stGenCRXer
Knife edging
Volumetric efficiency
Angle valve seat
The more cuts you make, the thinner the sealing area is going to be.
Valve guide
Leakdown
Pistol and mortar effect
Laminar flow
My main point of confusion is all the talk about cutting. What are you cutting, making cuts with, etc? Thanks for those of you who can clarify some of this for me.
Old Dec 26, 2002 | 07:59 PM
  #32
qtiger's Avatar
qtiger
In this context he's talking about the number of cuts involved in doing a valve job.
Old Dec 27, 2002 | 04:50 PM
  #33
ferrealb16's Avatar
ferrealb16
You're obviously from the "more is better" crowd, in which case I would have to say you have a lot to learn.
really, i have a lot to learn? the first time i p&p'ed my head, i was runnin with si's/teg's with major bolt on mods. then i went and bought ctr cams and some adj. cam gears and was beatin prelude sh's with cai, header, and exhaust. ive learned what i need to learn. i was taught from one of the best, his name is ralph shumacher.
thought the valve guide sat above the valve seats. in fact, i thought the valve guides sat higher than the port does. but am i wrong, probably not. at the time i first wrote that, i had just gotten my head back from the machine shop. and the guy who cut my valve seats did a raduis valve job on his yamaha r1...much smaller valves, much smaller ports, much smaller seats.
didnt i say you dont want to polish it too much because it will effect atomization. once again i was taught by one of the best.
Finally, there's no question Ferrea makes quality parts. The simple truth is that it's hard to swallow the price, especially when 99% of engine builders are not trying to get 150%. For all-out racing applications, your suggestions hold a bit more water, but for street driving, even I have to call it overkill.
well personally, jun valves are crap, skunk2 is bunk, mugen is a complete joke. its not called over kill, its called doing it right the first time, the only time. complete ferrea valve train minus roller rockers/cam for around 1300. when buying internal engine components, you get what you pay for.
oh yeah, the guy who is helping me build my engine can bench grind sohc cam that gained him 27 hp.
Old Dec 27, 2002 | 05:06 PM
  #34
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
The cutting is at the valve seats. You cut them using an uh, "valve seat machine."
I wouldn't call them crap. I would say they're not worth it. The stock valves are more than suitable for all but the most extreme applications.
Great, now you can have one of these:
Old Dec 27, 2002 | 06:10 PM
  #35
1stGenCRXer's Avatar
1stGenCRXer
GWAKS- Tech Geekifier
I already beat prelude SH's, and... hmm... I haven't even touched the head yet. No cam, only portmached the header and intake manifold to the head. A good engine builder will help you learn, but that's no reason to start thinking you know all the tricks until you start building your own and making your own name. To date I've built everything from 289's, 302's, 350's, 454's and 460 v-8's down to 30cc weedeaters, which includes scratch building exhaust manifolds. It appears I haven't been able to build my ego quite as much as you, however.
They do sit above the port, but they still get moved around by the rockers. The larger the valve, the larger the degredation rate once it starts.
Knowing and knowing why are two different things.
Everyone's entitled to their opinions, however, there isn't any reason for joe-schmoe to drop 1300 if all he's doing is a mild build-up. That's all I'm saying. If you're going for an all-out cost-no-object build, then by all means.
I keep seeing this "the guy who is helping me" pop up. Normally I wouldn't cut anyone down for being helped, but with the kind of stuff you're trying to push, it leads me to believe that you don't know the entire reasons behind certain things. Most of us in this forum are either taught and experimented under supervision [like me], or absolutely refuse to have anyone but them touch thier car [most everyone else], and come here for the "what if"s, "why is it"s, and "how does X work" questions. This is NOT the place to try and win an ego contest or to say "my checkbook is deeper".
Old Dec 27, 2002 | 07:49 PM
  #36
Dave C's Avatar
Dave C
Wow. What a discussion. Head modification should be driven by the intended service (street, strip, road course).
I've only been into the C32A1 engine (G2 Legend) and those are the shortest, straightest ports I've ever seen (used to play with all sorts of american iron). I would think the 4cylinder heads are similar. IMO all they need is port matching and blending of the valve guide boss on a street engine.
On the subject of polishing and atomization: Those concerns apply to carbed engines. Injectors fully atomize the fuel (when clean) and are timed to valve opening. C32A1 injectors are aimed directly at the intake valves, bet 4 cylinders are the same.
Finally: Head porting is as much an art as it is science. Chose your "artist" based on his previous work.
Old Dec 27, 2002 | 08:34 PM
  #37
qtiger's Avatar
qtiger
Why? Back up your hypothesis with data.
As for you and your Ferrea valve train, what if their spring rates don't match what you want? There is a proper solution for every application.
Old Dec 28, 2002 | 05:13 AM
  #38
1stGenCRXer
The injectors are pointed at the valves, but I was referring to fuel dispersion, not atomization, sorry for any confusion.
Old Dec 28, 2002 | 07:39 AM
  #39
livelyjay's Avatar
livelyjay
So when you replace the valve springs you have to worry about those spring rates as well? What would happen if you got incorrect spring rates? What difference would different spring rate make?
Old Dec 28, 2002 | 12:35 PM
  #40
Snoopy's Avatar
Snoopy
been there done that
the springs might be too hard not allowing the valves to open fully or they might be too soft allowing the valves to open too much which might cause it to hit a piston = bent valves.
