all motor d16y8
The reason I brought up the dyno is that if a shop doesn't have a dyno it tends to fall into one of two categories:
1. It's just getting started out so they can't afford a dyno yet, or they just want to be a source of quality wrenching and not a full-fledged tuner. But they'll refer you to a place to have your tuning done and they won't feed you B.S. flywheel hp numbers.
2. It's purely a money-making operation and they want to play as many kids as possible for thousands of dollars worth of stuff that doesn't quite work like they claim.
Just from how you're describing the place it sounds like it fits into the second group.
Sort of on a side note...
with a 220WHP D-series engine, you're gonna go thru axles and transmissions like mad. You gotta think of that side of the equation too. A 200+ hp SOHC honda is a screaming fast car, but you're paying for lots more than the engine.
aight... i went back to the shop today and here's what i got..well here's what me and my friend got!!.. 2 Garret turbos, 2 HKS Manifolds, 2 HKS wastegates & install for $5000 !!! tell me that's not a deal... that's $2500 a piece for turbos.. and install!! they said if i bring them a BOV and an intercooler they will install those at no extra charge.. so we are going 2morrow to some junkyards to find one of those factory BOV's and intercoolers off of like a saab or eclipse or something!! sound good?? let me know what you think!!
Taylor
Taylor
So you got a turbo, manifold, wastegate and labor for $2500. You still need charge pipes, an intercooler, blowoff valve, and a method of tuning the motor which this shop does not appear able to provide.
Wow! That IS a good deal
Thats also a cool forum! However I am going to build a ALL MOTOR D16A6, any sugestions? Here is the deal with it: 150xxx miles (needs rebuild) Probably gonna slap a Y8 head on it (I heard the A6 bottom end is the best in the D sieries) If I did, would all the stuff for my A6 head fit on the same? Manifold, Header, 11:1CR pistons and so on? Give me your oppinions.
BTW my reasons for not going boost are reliability, my moms is b*tchen bout me doin a motor swap, and if I do an ALL MOTOR build up over time she cant b*tch ALL at once... This I can take. I dont mind b*tching spread out over a year or two but ALL at once meens I get booted out of the house and I have to move to humboldt again :~
Thats also a cool forum! However I am going to build a ALL MOTOR D16A6, any sugestions? Here is the deal with it: 150xxx miles (needs rebuild) Probably gonna slap a Y8 head on it (I heard the A6 bottom end is the best in the D sieries) If I did, would all the stuff for my A6 head fit on the same? Manifold, Header, 11:1CR pistons and so on? Give me your oppinions.BTW my reasons for not going boost are reliability, my moms is b*tchen bout me doin a motor swap, and if I do an ALL MOTOR build up over time she cant b*tch ALL at once... This I can take. I dont mind b*tching spread out over a year or two but ALL at once meens I get booted out of the house and I have to move to humboldt again :~
the turbo is a complete kit.... !! all piping and everything included... !!.. intercooler and BOV i can get off a stock eclipse for cheap as hell...this is a bad setup for this price...!!
taylor
taylor
taylor
taylor
