Boosted B16a problem
Old Aug 26, 2007 | 12:22 PM
B16a2VTIguy's Avatar
B16a2VTIguy
Built B16a
Default Boosted B16a problem
I have a b16a2 build turbo'd, im using the following parts..
*je 9.0.1 pistons
*eagle rods
*cometic .051 h/gasket
*cheap ass t04e turbo
*fmic
*RC 440cc injectors
*38mm wastegate
*ngk bkr7e plugs (colder)
*255lph walhbro
*3 bar map sensor
*2.5" charge piping
etc etc
My motor has only just been built and i have installed the piston rings as per je instruct, but my motor burns oil particually on boost.
A freind recommends putting a bung in the exhaust to give it a bit of back pressure to resolve this as he says its the cheap ass turbo thats the problem....its the oil seal ring in the turbo doesnt house in place due to the cheap cast?
Does this sound right?
Also, just wandering whats the max boost/power ill beable to have with the 440cc's?
Thanks again for any help, ste
Old Aug 26, 2007 | 05:57 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
Have you done a compression and leakdown test on the motor to confirm whether it is a poor ring seal or blown turbo seals? Regardless, don't listen to your friend. What is backpressure going to do to help oil consumption in any way? Nothing.
You will have to see when you run out of fuel on those injectors. Do you know what your fuel pressure is? I know with my Walbro, it upped my fuel pressure so I am running a surprisingly low duty cycle for my power level. Those will be the limiting factor on your setup, so it may be worthwhile to upgrade sooner than later.
Old Aug 27, 2007 | 08:23 AM
B16a2VTIguy
Built B16a
Its standard fpr at the moment, but i have a adj fpr to fit.
Ive just been reading this, note point 29. http://www.turbotechnics.com/docs/turbo/tips.htm
Is this even a possibility?
Old Aug 27, 2007 | 04:00 PM
KaoticBRD's Avatar
KaoticBRD
Do you only see smoke under boost? Or do you even see any smoke? If so what color?
If its black you’re probably running lean under boost.
Old Aug 27, 2007 | 05:27 PM
Provocateur
On permanent hiatus
A FPR isn't going to help without a gauge to see what your static pressure is. B&M is junk, so if you have one of those, get rid of it and get something that allows you to turn the pressure down.
And point 29 is bogus. A free flowing exhaust reduces backpressure decreasing lag and engine temperatures. A turbo engine will always benefit from a free flowing exhaust of the proper size for the engine and turbo setup.
Old Aug 27, 2007 | 05:47 PM
FLAT_LINER's Avatar
FLAT_LINER
Ridin Dirty
lean?....black = running rich
Old Aug 28, 2007 | 07:50 AM
KaoticBRD's Avatar
KaoticBRD
I've seen a few cars that were leaned out put out black or dark smoke. It only did it for a few days and then they poped! You could see it in the cylinder walls where the piston was rubbing. I don't know if it was oil burn off or what that was making the smoke.
Old Aug 29, 2007 | 12:24 AM
B16a2VTIguy
Built B16a
The FPR has a gauge so i can see the pressure, ive booked it into the RR to get tuned properly on the 7th.. the guy had a quick check of it and said it was running hella rich....but safe.
My friend has a new turbo of a impreza sti (roller bearing turbo etc, he said the 1.8t audi/vw guys are making around 380hp with it.....mite use that as its a very reliable turbo.....especially as im running a ss autocrap one.
Good idea?
Old Aug 29, 2007 | 09:44 AM
Provocateur
On permanent hiatus
You would have to change out your manifold since the T3 and T28 flanges differ. I would just pick up a decent 57 trim somewhere and call it a day.
Old Sep 6, 2007 | 01:36 AM
B16a2VTIguy
Built B16a
Yeh im gonna look into getting a new 57 trim one i think, but turbos aint cheap so i just need to find a reasonable price on a good quality garrett or something, thanks for the help.
