Starter and some other probelms
Old Oct 9, 2002 | 08:26 PM
Macster33's Avatar
Macster33
Hottest of the Hot
Default Starter and some other probelms
Can someone please tell me where the starter is located?
Heres the story
1995 Accord Coupe / 78,000+ miles
Took my car out of my garage and drove it down the street just fine, then midway in second gear, (just teling you what gear i was in), i heard this loud grinding noise then the car turned off. Tried starting it again and it will crank but wont start.... well eventually from trying that now the starter is ****ed cause it no longer cranks, just clicks. in order for me to find out what the hell the grinding noise is i gotta get the car started. The battery is fine, and so is the distributer and timing belt. But right now i need to get the starter off, where is it located? And what do you think the grinding sound might have been? the starter? the tranny? the engine?
Old Oct 9, 2002 | 09:46 PM
inspyral's Avatar
inspyral
のんびり~(´ε`)
The starter should be toward the rear of the tranny. It's bolted to the tranny, and its gear protudes inward to engage the flywheel and crank it, which starts the engine. The clicking sound is usually from the starter not being able to engage the flywheel. Your starter should look something like this:
Old Oct 10, 2002 | 03:33 PM
ccpp's Avatar
ccpp
Are you sure the timing belt is ok?
After you install a new starter, open the oil cap to make sure the valvetrain is moving when you crank the engine.
Old Oct 10, 2002 | 07:40 PM
Macster33's Avatar
Macster33
Hottest of the Hot
sorry i didnt know where exactly to start this thread but its continued over here,
thanks
https://www.honda-acura.net/forums/s...threadid=27010
Old Oct 10, 2002 | 08:31 PM
inspyral's Avatar
inspyral
のんびり~(´ε`)
If your starter is stuck, I would check for flywheel damage as well.
Old Oct 10, 2002 | 08:36 PM
Macster33's Avatar
Macster33
Hottest of the Hot
**** man! check for flywheel damage!!! arrgh seems like one probelm after another, yea i got the starter out, but to look at the flywheel, this sounds like a chain reaction of probelms, i bet i am goin to have to get a new engine.
i really dont want to take my car down to honda and get pissed on in labor charges, how would i check the fly wheel?
Old Oct 10, 2002 | 09:28 PM
inspyral's Avatar
inspyral
のんびり~(´ε`)
Just rotate the engine via the crank pulley and shine a light thru the starter hole and make sure the teeth on the flywheel aren't messed up. Taking your spark plugs out will make it easier to riotate the engine by hand. The crank pulley bolt is 17mm, I believe, and you should rotate it counter-clockwise.
Old Oct 13, 2002 | 10:04 AM
Macster33's Avatar
Macster33
Hottest of the Hot
Ok, since i am going to rotate the engine via the pulley, shouldnt i be able to kinda feel/hear the pistons moving up and down? cause those might be ruined if my timing belt isnt on
Old Oct 13, 2002 | 12:19 PM
inspyral's Avatar
inspyral
のんびり~(´ε`)
Why isn't the timing belt on?
Old Oct 13, 2002 | 12:28 PM
Macster33's Avatar
Macster33
Hottest of the Hot
its on but we its worn out, and could have possibly jumped a tooth, we are just going on theories of why i heard a deep loud grinding sound.
