tranny slipping
Old Aug 7, 2006 | 10:05 PM
RacingDA's Avatar
RacingDA
Default tranny slipping
i have a 90 ls.. and my tranny is slippin gear. it wiont stay in second unless i hold the shift down and when im drive in 5th i would pop outta gear every 5 mins or so. any idea wats wrong with it. is it the tranny or my clutch?
Old Aug 8, 2006 | 01:24 PM
dmacaalay's Avatar
dmacaalay
Monkey See, Monkey Do!
im thinkin its the tranny.. you would know if the clutch was going out because the rpm will rise while your speed stays the same.. almost like you are in neutral..
Old Aug 8, 2006 | 06:06 PM
RacingDA's Avatar
RacingDA
thanks for the reply it really helps me narrow down the problem
Old Aug 9, 2006 | 11:32 AM
mberndt's Avatar
mberndt
First and foremost, check the condition of your motor mounts.
If the engine is not sitting correctly, it can put a strain on the shifting components, causing the car to pop out of gear...
I had a similiar problem popping out of 3rd gear, I knew it was because my engine mount (timing belt location) was bad... I replaced it with a new one, and my problems were gone...
My guess is it has to do with the linkage.
Check it out & let us know.
Old Aug 10, 2006 | 01:31 PM
RacingDA's Avatar
RacingDA
thanks a lot mberndt i was hopin someone told em that. ima have that take a look to save more money. i was check my car and the front mount was missin a bolt and the linkage was kinda outta place
Old Aug 11, 2006 | 10:25 AM
mberndt's Avatar
mberndt
Hey, no problem man...
I'm here to help...
Get a bolt in there where you are missing one, and I bet it fixes your problem...
Lemme know what happens...
Later
Old Aug 11, 2006 | 06:17 PM
RacingDA's Avatar
RacingDA
i just put on the mountin bolt and it helps a lil.. it doesnt pop outta gear aas much as b4. but my linkage joint is still kinda bent so ima try and get new bushin and see wat happen then
Old Aug 14, 2006 | 10:05 AM
mberndt's Avatar
mberndt
Cool, glad I could help...
Get that bushing replaced, and let us know how it is...
Later
j87w
4
Jan 2, 2005 08:53 AM
CRAZYEG9
92+ Civic/EL & Del Sol
8
Oct 20, 2004 08:14 PM
ZiviCase10287
Engine Swaps, Tech & Tuning
2
Feb 27, 2004 08:30 AM
He123321
Accord
4
Dec 4, 2003 08:50 AM
