Mini-me reliability
Old Aug 23, 2006 | 08:59 PM
Omie's Avatar
Omie
ew n!gg@ u g@y
i mean 180 is my goal, but anythin better then 96 whp would suffice, i dont wanna spend to much into it, but if i had to i would trust me for the longest time i wanted to do a k20 wit 6 spd tranny, but i realize, that the car is goin to my girl and ill be pushin a new car soon
Old Aug 23, 2006 | 10:38 PM
ddd4114's Avatar
ddd4114
if you don't plan on keeping the car for long, don't spend too much - just focus on reliability (timing belt, water pump, etc.). If you're using a mini-me, some sort of engine management wouldn't be a bad idea.
Then again, if you can afford a k20...
Old Aug 26, 2006 | 04:08 PM
ReVenGe's Avatar
ReVenGe
im under the impression that i can just use my stock d15b7 wiring harness.
what im swaping in is a p28 ecu, and a y8 head....
Old Aug 26, 2006 | 04:14 PM
ddd4114's Avatar
ddd4114
I'm using my stock wiring harness (b7) with a z6 head. I used a p28, too. You have to wire up the VTEC solenoid though, which will require a cheap harness that you can buy for like $20, or fabricate yourself for even less. It just accomodates a plug for the oil pressure sensor and the actual solenoid.
Old Aug 26, 2006 | 09:53 PM
ReVenGe's Avatar
ReVenGe
i love it when people can answer questions like that...
so ok... i think i've seen the homemade one on another forum.... but i can buy a clip that connects to the vtec wire?
Old Aug 27, 2006 | 06:40 AM
ddd4114's Avatar
ddd4114
to the solenoid plug? yes - for a few bucks at the most.
Old Aug 28, 2006 | 04:57 PM
ReVenGe's Avatar
ReVenGe
how did you handle the timing? did you take it to a shop?
Old Aug 28, 2006 | 06:09 PM
ddd4114's Avatar
ddd4114
I actually didn't do too much with the timing, though I wish I did.
For the ignition timing, I just rotated the distributor as close to stock timing as I could. I'm still 1 or 2 degrees off because I'm using a hacked up b7 distributor, and the housing only goes so far. I could file even more material off, but I don't want to weaken the frame even more than it already is.
For cam timing, I set it as close to 0 degrees as possible. I'm using an adjustable cam gear to correct for the 4.5 degrees off issue that many mini-me's encounter.
I did not take the car to any sort of shop. However, I am letting an experienced tuner handle wideband o2 tuning, since the equipment is on the expensive side.
Old Aug 28, 2006 | 10:06 PM
ReVenGe's Avatar
ReVenGe
yeah..... i think im gonna put it all together.... and then have AAA tow it to a shop even before i turn it on.
Old Aug 28, 2006 | 11:11 PM
ddd4114's Avatar
ddd4114
I think you'll be fine; it really wasn't that hard. If you're completely stumped, then a shop can take care of it.
