B16 turbo??
Old Dec 13, 2005 | 10:04 AM
  #31
B16a2VTIguy's Avatar
B16a2VTIguy
Built B16a
Is DSM a manufacturer? I'm not going higher than 12psi so i'm not gonna run more than like 250whp am i? Whats the differance between saturated and peak hold? If i'm gonna buy some should i go for say 756cc or are they too big for me with my current goals?
Old Dec 13, 2005 | 10:28 AM
  #32
b16ahybrid's Avatar
b16ahybrid
DSM = diamond star motors (mitsubishi)...The eclipse came with 450cc injectors from the factory, you can pick them up for about $50 or so.
depending on your turbo size and tuning...12psi could be anywhere from 250whp to 350whp...I'd say closer to 300whp if you stick with a t3t40E.
Saturated = high resistance, they are what you are currently running....
Peak hold is low resistance and used in older cars. Until recently you had to run peak hold if you wanted to run large injectors....RC now makes large saturated injectors.....
450cc injectors will work (up to about 300whp) but if you can find some 550cc+ they will give you room to grow...
Old Dec 13, 2005 | 11:56 PM
  #33
B16a2VTIguy
Built B16a
well as long as 550cc will work fine i'll get them and give myself room to grow, i'm probs gonna have to buy new ones coz the aint any eclipses in scappys in uk, not a very popular car over here.....i will look for another car i could get them off tho and check what injector type they are.
Also is a return oil feed needed from the turbo? or just one feed from oilsandwich to turbo? Any ideas of where i can get a good turbo manifold and down pipe without being "mad" prices? bear in mind i live in the uk and delivery costs. thanks
Old Dec 14, 2005 | 06:31 AM
  #34
b16ahybrid's Avatar
b16ahybrid
Yes you need to have a oil drain line that drains back to the oil pan....
Try e-bay for a manifold, just avoid ssautochrome manifolds....
Old Dec 15, 2005 | 11:51 AM
  #35
B16a2VTIguy
Built B16a
I know someone selling some used 450cc saturated injectors for 100 pounds, u guys reckon this is worth the money?? also how do i take the air flow from the turbo to the inlet?? do i just take a pipe up and put it next to the filter or what???
Old Dec 15, 2005 | 07:28 PM
  #36
b16ahybrid's Avatar
b16ahybrid
http://www.honda-tech.com/zerothread?id=1323059&page=4
The filter goes on the inlet to the turbo, the outlet of the turbo connects to the intercooler through a pipe, the output of the intercooler connects to the throttle body....using a pipe...I'll e-mail you pics of my engine bay....
Old Dec 15, 2005 | 07:34 PM
  #37
b16ahybrid's Avatar
b16ahybrid
pics sent
Old Dec 16, 2005 | 08:43 AM
  #38
B16a2VTIguy
Built B16a
thanks b16ahybrid, what do u reckon bout the 450cc saturated injectors for 100 pound?? (quid- lol!)
Old Dec 23, 2005 | 08:49 AM
  #39
B16a2VTIguy
Built B16a
Default Turbo kit
So whats every1's ideas on those 450cc injectors for 100 pounds?
Also do i really need a intercooler?? what would happen if i did'nt use one??? less power etc??
Old Dec 23, 2005 | 08:51 AM
  #40
B16a2VTIguy
Built B16a
Default bump
bumpity bump bump
