B16 turbo??
Old Dec 23, 2005 | 06:32 PM
  #41
b16ahybrid's Avatar
b16ahybrid
Originally Posted by B16a2VTIguy
So whats every1's ideas on those 450cc injectors for 100 pounds?
Also do i really need a intercooler?? what would happen if i did'nt use one??? less power etc??
Seems kind of high for injectors (dsm) I can usually find them for about $75 us currency.
An intercooler is highly recomended, not only will it give you more power it will give you more reliability....Cooler charge temps (as a result of using an intercooler) will lessen the chances of detonation and in turn will make more reliable power.
Old Dec 27, 2005 | 11:42 PM
  #42
B16a2VTIguy's Avatar
B16a2VTIguy
Built B16a
Gr8, looks like i'm gettin a intercooler then, cheers
Old Jan 15, 2006 | 12:03 PM
  #43
B16a2VTIguy
Built B16a
OK, i'm decided.......i'm gonna turbo! I'll buy the turbo manifold and turbo first, so are the OBX manifolds any good? Also can someone explain to me what a .57 trim and .63 A/R mean. thanks, ste
Old Jan 22, 2006 | 01:15 PM
  #44
B16a2VTIguy
Built B16a
  #45
B16a2VTIguy
Built B16a
bumity bump, bump
Old Jan 29, 2006 | 09:27 AM
  #46
B16a2VTIguy
Built B16a
I Need some sort of management for my turbo setup, what ecu would you recommend? will my motor still run with the turbo kit fitted and stock ecu? will i beable to do a basic map on my new ecu (whichever one i get) so i can drive the car to the dyno?
Old Jan 29, 2006 | 09:54 AM
  #47
b16ahybrid's Avatar
b16ahybrid
Which ecu do you have now p30?
You can use that ecu and chip it with hondata or any of these ecu's
P28,P72,P61,P08J,P30J,P72J...
Or you can run uberdata.
Old Jan 29, 2006 | 11:29 AM
  #48
B16a2VTIguy
Built B16a
how much is uberdata and how do get it in the UK? can you change the mapping on the computer?
Old Jan 29, 2006 | 01:50 PM
  #49
b16ahybrid's Avatar
b16ahybrid
Uberdata is free sofware, you need to chip your ecu.
It allows you to change your mapping for boost.
Old Feb 3, 2006 | 07:07 AM
  #50
B16a2VTIguy
Built B16a
Ok great!, how do i chip my ecu then and where do i get the bits or "chip" for it? Also were will i gt the uberdata software?
