Should I replace my...
Old Mar 17, 2004 | 06:37 AM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
Default Should I replace my...
main and rod bearings, and my thrust washers if I only have ~15k mi on my rods and crank and I'm going to be putting them into another block?
I'm getting another GSR block to have it built and then going to swap my internals over to it that I'm currently using. Normally I would just replace everything, but I don't think it's necessary... thoughts?
Thanks!
Old Mar 17, 2004 | 06:59 AM
shivers's Avatar
shivers
Moderator Alumni
I would ... just extra insurance in my book since everything is coming out and going into another block.
2005 s2000
Old Mar 17, 2004 | 07:20 AM
qtiger's Avatar
qtiger
You'd be pretty lucky if the main journal bores are all the same.
Old Mar 17, 2004 | 07:57 AM
westcoaststyle
Oh, that's right. I forgot that they use different 'colors' for the journals. Dangit!
I should be ok with the same rod bearings though cause it'll be the same crank and same rods, just in a new motor... right?
Thanks!
BobCarter
92+ Civic/EL & Del Sol
Aug 17, 2003 04:15 PM
loodboi
26
Jan 14, 2003 03:08 AM
rivvin
21
Nov 5, 2002 04:47 PM
ElectronBlueGSR
17
Nov 1, 2002 12:31 PM
kfar09
4
Oct 29, 2002 11:51 AM
