lowering a car
Old Aug 12, 2002 | 04:23 PM
excitid's Avatar
excitid
Default lowering a car
does lowering affect axles at all. I am asking in general and also in reference to 4wd wagons. I'm just curious if the change in ride height affects the how long they last.
Old Aug 12, 2002 | 04:29 PM
FourthGenHatch's Avatar
FourthGenHatch
I'm RICK JAMES, bitch!
I doubt it does, as the suspension would cushion anything that it encounters, and plus with the fork the axel is never really in danger.
Old Aug 12, 2002 | 05:51 PM
WhiteRice's Avatar
WhiteRice
I've heard it does bad things to the axles if you push the wheels out of the wheel well......alot of the Mexican guys here in Denver do that....:ghey:
Old Aug 12, 2002 | 06:31 PM
jaje's Avatar
jaje
HC Racer H5
axles i'm not sure but it's not the way it is stock so it may wear them out faster...but not by much
as for lowering your camber will be off and will wear out tires faster
lowering your car will most obviously make your car much rougher to ride in b/c of the reduced suspension travel...when lowering make sure you don't use cut stock springs as they will not dampen the bumps enough to prevent constant hitting of the bump stops
be smart and get a coilover kit that allows you to adjust ride height (like ground control kit)...this is a neat option so you are not stuck with too low of a ride
madhandles03
92+ Civic/EL & Del Sol
5
Jul 26, 2003 08:28 PM
acord2001
Accord
6
Jan 25, 2003 07:07 PM
90'RS
8
Oct 2, 2002 08:12 PM
h0ckeyplr
8
Sep 22, 2002 06:56 PM
integra-boy
3
Aug 1, 2002 08:06 AM
