Subwoofer not working?? HELP
Old Jun 27, 2002 | 08:32 PM
Johnny Tran's Avatar
Johnny Tran
inside the box eh?? do you think it would've moved or something?
Old Jun 27, 2002 | 08:51 PM
b00gers's Avatar
b00gers
never hurt to see.
Old Jun 27, 2002 | 10:11 PM
OneToughCivic's Avatar
OneToughCivic
cut a lead of speaker wire (about a foot or two) and strip both ends. put one end in you sub box and touch the other end to a battery, like from a cordless drill or something. i always use my 9.6v makita batteries to pop speakers. that will tell you if your sub is hooked up or not. also you can test the ohms across the speaker. if you get nothing then it's not connected, if you do get a reading then it's hooked up. sometimes the leads come off of the terminals inside the box. good luck son
Old Jun 28, 2002 | 10:05 AM
smokedogg's Avatar
smokedogg
definatly worth a try, make sure theyre tight on the speaker and tight on the box connections.
if all else fails, try hooking up a friends deck to your amp. Or even go to a stereo shop and ask to try a new deck. It could be your RCA outs on the HU
Old Jun 28, 2002 | 10:19 AM
97teg's Avatar
97teg
Be careful only to touch the the leads to battery and not hold them on.
bostonteg
18
Aug 28, 2021 11:57 AM
civickid77
92+ Civic/EL & Del Sol
3
Oct 24, 2002 04:03 AM
Sushiboy
5
Aug 20, 2002 10:43 PM
SHAUNTS99
19
Jul 2, 2002 09:20 PM
bluedream
Engine Swaps, Tech & Tuning
3
Jun 21, 2002 02:12 PM
