Taillight Not Working (It's Not the Bulb)
Old May 12, 2005 | 07:11 AM
bostonteg's Avatar
bostonteg
Default Taillight Not Working (It's Not the Bulb)
Ok, i changed my bulbs thinking it was as simple as that, and they still dont work...my reverse light works, brake light works, but the taillight and the red corner light dont work (driverside rear)...i have a fuse tester and checked a number of fuses...i dont have the chart that shows which fuse is for which, so if anyone could get that posted that would be cool...or if ne1 knows why they arent working write back...
Old May 12, 2005 | 10:00 AM
Exadar's Avatar
Exadar
Be Quiet and Drive
I don't know too much about the wiring harness for the back, but could the wire for those lights be corroded or something? just tossing out ideas here
Old May 12, 2005 | 01:20 PM
civicandtegra's Avatar
civicandtegra
r u sure its not the bulb lol
Old May 12, 2005 | 03:44 PM
bostonteg's Avatar
bostonteg
positive its not the bulb just changed it today...and the bulb works fine as a brake light just not as a taillight
Old May 14, 2005 | 06:17 PM
bigt61's Avatar
bigt61
I have the same problem. my brake light and reverse light works. but no turn-signal light from the drivers side tail light. I've checked everything out too. All the fuses and bulbs are good. anybody have any suggestions for us?
Old May 14, 2005 | 06:25 PM
Seyless's Avatar
Seyless
First make sure you have the right bulbs, then I would check fuses, then I would test wire connections and check for voltage along the circuit. Lights are run parallel so that if the circuit is open to one bulb the others won't go out.
Old May 15, 2005 | 05:44 AM
civicandtegra
guys guys guys im sure of it now........ did u try the bulb
hehe
Old May 15, 2005 | 06:51 AM
needspeed's Avatar
needspeed
needspeed
Do your flasher's work if not it will be you relay some time's they go up .
Old May 15, 2005 | 09:32 AM
bigt61's Avatar
bigt61
Needspeed-
Yes, all of my hazard lights and EVERYTHING ELSE work- EXCEPT the drivers side rear turn signal/hazard signal. The turn signal and hazard use the same bulb. Yes, i have checked the bulbs and they are fine.
Old May 15, 2005 | 09:47 AM
Integral's Avatar
Integral
Nightmare Motorsports
Well that sucks for you guys ;p I'd play around with it myself, but I don't have that problem to fix at the moment!
