Taillight Not Working (It's Not the Bulb)
Old May 15, 2005 | 02:40 PM
bostonteg's Avatar
bostonteg
haven't been able to play with my car and fix the problem because i've been study'n for finals...bigt61, ne luck with fixing it?
Old May 15, 2005 | 05:25 PM
VPUPPY's Avatar
VPUPPY
i would check the harness that the bulb plugs into with a voltmeter(use dc voltage setting). you should be getting a reading of 0, 12, 0, etc out of one of the pins. then work your way from there.
Old May 17, 2005 | 11:15 AM
Try2Live4God's Avatar
Try2Live4God
Trying to figure out things like this is such a pain...
Old May 19, 2005 | 05:23 AM
bostonteg's Avatar
bostonteg
wow, i messed around with the light yesterday and i have no f'n idea what it is, it has to be a messed up wire sumwhere and thats just gonna be a pain in the ass!...i might give up and bring it to my buddy's shop...
Old May 19, 2005 | 05:39 PM
blackgsr65's Avatar
blackgsr65
dat thang got vtec???
get a manuel from advance auto or something. read the wireing diagram and try 2 isolate the prob. thats all i can say, i coul be a ton of things.
Old May 21, 2005 | 04:15 PM
bostonteg's Avatar
bostonteg
Woohooo!....fixed the problem gained another, lights now work...but now when i step on the brake and have the turn signal on to the left the signal goes crazy (blinks reallllly fast), i did two things...1. found a wire that wasnt connected which was the reason for the power loss and 2. moved my rca cable and remote wire to the opposite side of the car.....ne ideas why my blinker is acting crazzzyness
Old May 22, 2005 | 01:21 PM
bigt61's Avatar
bigt61
i fixed my problem too. ground wire wassnt grounded.
as for fast blinking- check your front turn signals. if they are blown- they can cause the circuit to operate twice as fast.
Old May 22, 2005 | 05:44 PM
bostonteg's Avatar
bostonteg
all the signals work...and the blinker stopped going crazy for the past few times ive been in my car so i think everything is good
Old Aug 28, 2021 | 11:57 AM
est4u84's Avatar
est4u84
Default I have the same problem
Hey brother can you please tell me how you fixed your tail light issue as I have the same on my 2006 Acura TL on the rear side Parker and tail light won’t come on the blinker and break light does work
