Disc Changer Questions
Hey I just got a cd changer for free from my freind that didn't want it. It is a EXCD-2RF sony 10 Disc cd changer. I believe it was made in 95. It is an add on cd changer but I wounder if can be changed so it can be controlled by a aftermaket deck instead of that gay controller. Because there is a controller in port and av out but i was woundering about the power to it, is it sent to it through the controller wire from the deck or what. I got it for free and it is in perfect condition but i was just woundering how to convert it.
Thanks, Evan :squint:
A little chin music
From: Cleveland, Ohio - Rock 'n Roll capitol of the World
So long as you have the data cable (the big, thick, black cable) you can do this. HOWEVER, I suggest you bring the data cable with you when you go to buy the head unit. Some Sony's have different bus connectors. There are 2 different ones: a 9 pin small connector (like a computer keyboard), or a large circular plug with a rectangular inner connector.
Power is sent through the data cable. When using the RF remote, the RF box is connected to your car's power and it sends power through the data cable. Same concept with a head unit, so no need to worry about running power to the changer itself.
One more thing. Using a head unit will make the changer sound better..... since RF uses FM radio, it has a 17khz ceiling (for the carrier frequency). Connecting it through the head unit will give you FULL badwith (20hz-20khz):bigok:
NWP4LIFE
Nov 11, 2003 01:14 PM
offthahook
Dec 24, 2002 12:07 PM
