Key Stuck In Ignition
Old Aug 21, 2004 | 07:28 PM
MPerson's Avatar
MPerson
You can't take the key out without the shifter being in Park. Have you tried that or is it not letting you shift into park?
If that doesn't answer the problem. Then I guess you'll have to take apart the shifter to see if something was shorted or removed from a harness :dunno:
Old Aug 22, 2004 | 10:48 AM
Nors's Avatar
Nors
倍力恋
I was installing an amplifier and had the key in the ignitoin to test it.. when i went to take it out it wouldn't come out, i wasn't done so i was like ill worry about it later, then i disconnected the battery.. key came right out..
I did have the shifter in "1"
So I'm not sure, maybe shift back to park and try, if your already in park, then I have no idea.
Old Aug 22, 2004 | 12:49 PM
MPerson's Avatar
MPerson
Yea, I am positive that in most cars they will not give you back the key unless the shifter is in park.
Old Aug 22, 2004 | 03:04 PM
Archon810's Avatar
Archon810
that is true, the shifter has to be in P position, then it'll let u have the key back. I've messed with my jetta when I had it, took apart the whole block only to find my shifter in D.
Old Aug 25, 2004 | 04:44 AM
ExiledinIN's Avatar
ExiledinIN
I had that problem w/ my acura. Maybe it's just that it needs to be adjusted. Take a look at this link.
https://www.honda-acura.net/forums/s...80#post1507680
Old Aug 9, 2010 | 12:13 PM
moonduck's Avatar
moonduck
Default Key Stuck in 98 Honda Accord Ignition
It's happened twice with mine now, and what worked the last time was rolling the gear shifter through all of the driving modes 2x back and forth, and then the key released.
Good Luck!
mishas
Accord
8
Sep 18, 2005 07:00 PM
MaNho
Prelude
9
Jun 18, 2005 11:10 PM
Momobile
Accord
6
Feb 3, 2005 05:30 AM
MilanoMan
92+ Civic/EL & Del Sol
6
Oct 2, 2004 03:12 PM
OutlawWPB
Accord
17
Oct 10, 2002 01:55 PM
