Key Stuck In Ignition
ok, this is my first post so i'll make it a good one. my car is a 1997 EX Sedan auto. the problem started when i was removing the center console to access my factory stereo to get the serial number. they key was in the ignition but the car was not on and the gear shift was in d2. while i was doing this my g/f accidentally moved the gear shift down to d3 which i don't really think affected anything. i put everything back together but when i tried to take the key from the ignition it would not come out. the car starts and runs perfectly but the only way to get the key from the ignition is to disconnect the battery, then the key just slides right out with the battery disconnected. i have to do this every single time and it sucks every time. what is wrong with my car?? any help would greatly be appreciated.
maybe you should play with that Shift Lock slot. stick your key in there, and shift the lever around.
then stick the key into the ON position and stick a flathead in the slot and shift the lever around.
try this, im NOT sure if itll work.
It's my first day.
is there some sort of electromagnet in there or something? i dont see how it is electrically holding your key unless that main relay has gone bad, i know that can effect 4th and early 5th gen models.
I don't know what the problem is, I have tried everything that has been posted here and have had no results. I know for sure that it is electrically/mechanically holding the key because when I disconnect the battery the key comes right out. When the battery is connected the key will not come out. How do I replace the main relay?
It's my first day.
Same thing happened to me with a 99 honda accord. Only able to remove the key with the battery disconnected.
I fixed it by taking the automatic shifter apart. I think something happened and it became misaligned inside. I put it back together and it worked again!!
Hope this helps
Hope this helps
