Autobahn Driven Accord / Needs Brakes
Old Sep 27, 2003 | 12:17 PM
Sigo's Avatar
Sigo
Default Autobahn Driven Accord / Needs Brakes
In the last year I've destroyed my front rotors (again). Need some stopping power that's resistant to fade.
Car is a 100mph Autobahn Daily Driven car (wife's) and need peace of mind for parts selection but at the same time I've earmarked Apr 04 as the target date for our new Honda Pilot.
With that said don't want to spend too much money for a caliper replacement kit.
Just want to focus on some crossdrilled with metallic pad replacement kit. Options?
side note: Thought I had the parts on order through my normal parts guy but he proved unreliable for Honda Aftermarket (great for the Syclone shit) so...need to find a place to buy and ship (summit?) from the phone / interweb.
Thanks in Advance.
Sigo's Avatar
Sigo
Meh forgot to add:
1998 Honda Accord EX 4cyl
Old Sep 27, 2003 | 12:20 PM
Sigo's Avatar
Sigo
figures after I initially post that I find another topic on this...
https://www.honda-acura.net/forums/s...threadid=97258
Don't know about applicability though.
Old Sep 27, 2003 | 12:31 PM
usc's Avatar
usc
if you're getting rid of the car soon (sounds like you're replacing it with the pilot), then i doubt it's worth doing anything to the brakes now.
with better brake pads and dot4 brake fluids, you should feel some improvement. as to fade... w/o spending some serious buckage, you're on your own on that one.
Old Sep 27, 2003 | 12:37 PM
Sigo's Avatar
Sigo
Yeah but the rotors have been turned already and are ready for lifecycle replacement. Understand the Dot 4...understand the metallic compound pads...but I also have heard that the cross drilled (which I have used on other vehicles with limited success) are just as cheap (or expensive depending on situation) as the stockers.
Understand also that the V6 over the 4cyl had bigger rotors (weight in the front end?) but the calipers were the same?
So am I looking for PowerStop Rotors for a V6 Accord same year or am I looking for pads / rotors from a manufactuar like AEM in a package for dummies?
Old Sep 27, 2003 | 05:26 PM
usc's Avatar
usc
i don't have the specifications for the v6 rotors (whether they're thicker/bigger). if they are bigger/thicker, chances are you'll have to also get the v6 brake calipers to make everything work.
there's a couple of possibilities going on here in your scenario:
1) you're pushing the brakes to the limit but you're not allowing it to cool off properly, thus you rotors become glazed by pad deposit.
2) you're pushing the brakes BEYOND its limit thus experience fade.
if you're having fade, then it may be wise to invest in a bigger rotor kit (not so much because of x-drilling or slotting, but because bigger rotors are more resistant to temperature change.
if you're just warping rotors, then you're not allowing the rotors to cool properly. for instance, if you brake from 100-0, and keep the foot on the brakes (especially because if the car is an automatic), then the rotors are being cooled unevening when the car isn't moving. the part of the rotor touching the brake pads will cool at a different rate than the rest of the rotors exposed to just air. you end up glazing the rotor and leaving imprint/deposits of the pad.
the cure to this obviously is having brake setups like Porsches and Ferraris (whose rotors are huge, directionally vaned for cooling), designed for high speed stops.
Old Sep 27, 2003 | 05:38 PM
92lx
Guest
Posts: n/a
a good synthetic brake fluid, and smarter driving should save you the expense until getting a new car. If you want cross drilled, grab you some regular ol' brembo rotors. If you want slotted or cross-drilled that's up to you. Either way the amount of heat disipated by them will be very little for them to make much difference. The best idea would be to run some kind of brake ducting system to cool the calipers. Good luck
- Nathan
Old Sep 27, 2003 | 05:56 PM
AccordManiac's Avatar
AccordManiac
Korean Member
yah.. blank Brembo rotors!!!
Old Oct 4, 2003 | 02:38 PM
Sigo's Avatar
Sigo
Now I can honestly say that I have learned something today. Interesting.
I had heard that the V6 used slightly larger rotors but same calipers, rotors and thusly would be more efficient for high speed braking.
Gonna call summit here in a bit and see what they have to offer.
Old Oct 5, 2003 | 09:02 AM
lil_1_2002's Avatar
lil_1_2002
Yes the v6/wagon rotors are 11.2 inches and the stock accord are 10.2. You can do the swap, its a direct fit and you need the wagon calipers aswell, i just did mines 2 weeks ago and its very nice. Also try S/S lines that work great and are around 100 bucks. here are some pictures of other swaps and of my mines.
Accord vs V6/Wagon
Accord pad vs v6/wagon pads.
