If anybody has specific technical or TSB questions...
Old Aug 12, 2005 | 07:55 AM
  #61
kmurph's Avatar
kmurph
I have a 1999 Accord EX V6 Coupe ...and just ordered a new main relay which I hope will take care of the intermittent starting problems I've been experiencing recently. ...I think I've located the main relay under the driver's side dash but I'm not 100% sure...Do you have a diagram which shows where every fuse and relay is located?
Old Aug 12, 2005 | 08:01 AM
  #62
98CoupeV6's Avatar
98CoupeV6
lots and lots of fail
Sure do:
The owner's manual (I think, I haven't used mine in a long time since I got a Helms) and the fuse doors will tells you what each fuse does.
Old Aug 12, 2005 | 08:09 AM
  #63
kmurph's Avatar
kmurph
Originally Posted by 98CoupeV6
Sure do:
Thank you soooo much! I've looked so many places and have found nothing. The fuse box does have labels for the fuses and some relays but I just could not find any info regarding the Main Relay or if there was a separate fuel pump relay, etc...I found a bunch of stuff for previous generations but that was about it.
Old Aug 12, 2005 | 09:06 AM
  #64
98CoupeV6's Avatar
98CoupeV6
All I require is your M3 for a week h:
Are you replacing the PGM-FI relay?
Old Aug 12, 2005 | 11:21 PM
  #65
95StockGSR's Avatar
95StockGSR
98CoupeV6,
I have couple of problems with my "2000 Accord EX V6 Sedan."
It would be great if you can post TSB regarding below mentioned items.
00-064 AUG 04 Body - Deformed Windshield Moulding
02-010 JUN 02 Interior - Seat Back Panel Loose/Detached
00-095 MAR 02 Body - Moonroof Seal Squeaks
00-038 AUG 00 A/T - Vibration When Driving at Low Speeds
96-012 JUL 00 A/C - System Performance Testing
Thanks in advance
Old Aug 12, 2005 | 11:22 PM
  #66
wedley2's Avatar
wedley2
bboy Wesley West
No problem
COMPONENT TORQUE
CLUTCH COVER 6 X 1.0 mm bolts 12 Nm (9 lb ft)
PRESSURE PLATE Mounting Torque [1] 26 Nm (19 lb ft)
[1] Tighten the bolts two turns at a time in a criss-cross pattern.
TRANSMISSION TO ENGINE 12 X 1.25 mm bolts 65 Nm (47 lb ft)
RING GEAR Bolts 101 Nm (74.5 ft. lbs.)
SHIFT CABLE BRACKET 8 X 1.25 mm bolts 22 Nm (16 lb ft)
TRANSMISSION BRACKET TO TRANSMISSION 10 X 1.25 mm nuts 39 Nm (28 lb ft)
MOUNT TO TRANSMISSION BRACKET 10 X 1.25 mm nuts 39 Nm (28 lb ft)
MOUNT TO BODY BRACKET 12 X 1.25 mm bolt 65 Nm (47 lb ft)
REAR MOUNT BRACKET STAY 10 X 1.25 mm nut 21 Nm (15 lb ft) 10 X 1.25 mm bolt 39 Nm (28 lb ft)
thanks, i finsihed my clutch today w/o purchasing any paper manuals h:
Old Aug 15, 2005 | 05:24 AM
  #67
98CoupeV6's Avatar
98CoupeV6
Originally Posted by 95StockGSR
98CoupeV6,
Thanks in advance
No problem, and welcome to HAN How many miles do you have on the Accord?
I can't upload the A/C file because it's too big. But the moral of the document is to take it to a professional because you most likely don't have the thousand dollar equipment and the service time is only a half an hour.
File Type: pdf
File Type: pdf
File Type: pdf
Old Aug 15, 2005 | 06:53 AM
  #68
mdvd's Avatar
mdvd
Default Need help Misfired in cylinder 1
96 Accord EX---Engine lights on.. and have check with 2 code detectors, both saying misfired in cylinder 1..( and only cylinder 1)
After reset for serveral time, I found every time the light come one at around 2300- 2700 rpm ( no matter what gear or shift up or down; if I stay in 2300-2700 rpm band for about 5 sec..the light will on ) .....feel a little bit lack of power..( maybe I saw the light and I feel it has some problem), A mechanic told me that it should be the distributor rather than the injectors, as he test the pressure and fuel feed of the car are ok... is he right? need some advice...
Old Aug 15, 2005 | 07:09 AM
  #69
98CoupeV6's Avatar
98CoupeV6
Your double post pisses me off, but since you're a noob I'll cut you slack.
For future reference, please post the trouble code
and not the description. Thanks.
DESCRIPTION
Misfire detection is accomplished by monitoring the crankshaft speed with the crankshaft speed fluctuation sensor which is attached to the crankshaft.
If misfiring strong enough to damage the catalyst is detected, the MIL will blink during the time of its occurrence, and DTC P0301, P0302, P0303 and/or P0304 will be stored. Then, after the misfire has ceased, the MIL will come on.
If misfiring that increases emissions is detected during two consecutive driving cycles, the MIL will come on, and DTC P0301, P0302, P0303 and/or P0304 will be stored.
Possible Cause
Fuel injector clogging, fuel leakage, air leakage
Fuel injector circuit open or shorted
Injector resistor malfunction
Spark plug carbon deposits, fouling, malfunction
Ignition wires open, leaking
Distributor malfunction
Compression low
Valve clearance out of spec
Old Aug 15, 2005 | 07:49 AM
  #70
hondarocket's Avatar
hondarocket
Thanks foe the info. A crossover is a device that only allows certain frequencies to reach the speaker. In this case they are filtering or crossing over low frequencies so that the tweeter only receives high frequency signals. Otherwise the tweeter could be damaged.
this is excellant info
thank you so much
hondarocket
