If anybody has specific technical or TSB questions...
Old Aug 10, 2005 | 05:11 AM
  #51
98CoupeV6's Avatar
98CoupeV6
lots and lots of fail
Originally Posted by hondarocket
Do you have any info on how to remove the door panels on a 2005 accord ex v6 coupe with 6spd manual tranny.
any pics or explanation would be much appreciated.
hondarocket
Good question. Here you go
File Type: pdf
Old Aug 10, 2005 | 06:41 AM
  #52
hondarocket's Avatar
hondarocket
thanks for the diagram.
you wouldn't happen to have the wiring diagram for the speakers.
this car has 6 speakers
2 17cm in door
2 6x9 in the rear deck
2 1.5" tweeters in the dash.
Specifically I'm interested in wether or not there is some sort of a crossover or filter in the head unit or in line to the 2 front tweeters.
I am trying to install a sub and a amp as well as replace the front and rear speakers but would like to leave the 2 front tweeters untouched due to their location.
If the tweeters are wired separately form the door speakers I should be able to leave them wired as they are.
thanks again for the diagram on the panel removal
hondarocket
Old Aug 10, 2005 | 06:50 AM
  #53
98CoupeV6's Avatar
98CoupeV6
2 17cm in door
hondarocket
Crossover network unit?? They got me.
Old Aug 10, 2005 | 09:28 PM
  #54
Jaison6976's Avatar
Jaison6976
Default 1990 Accord LX
Just purchased a 1990 Accord LX 4dr. automatic with the A-1 engine. I have a few things I need to replace and a couple of questions. I know that you probably get a ton of these so I will understand if you are too busy to help. Anyway here it goes.
1- My speedo is working intermitently. Was told it is a speed sensor. If so how do I replace?
2- Pasanger side front wheel clicking when I turn. What is the cause? and how do I fix it?
3- Check engine light comes on. Told it is an Oxygen sensor. If so a diagram of how to replace would be handy.
That is the short list. I would really appreciate any help. Thank you for your time. Just email me at jfk_enterprizes@hotmail.com with any help THANK YOU.
Old Aug 11, 2005 | 05:32 AM
  #55
98CoupeV6's Avatar
98CoupeV6
1) That's the vehicle speed sensor. Here are the instructions:
1) Disconnect the 3-P connector from the vehicle speed sensor (VSS).
2) Remove the mounting bolts, then remove the VSS. NOTE: The VSS drive link is a very small part, be careful not to lose it.
3) Install in the reverse order of removal.
COMPONENT TORQUE
SPEED SENSOR 6 X 1.0 mm bolt 10 Nm (7 lb ft)
2) Once again, I am not diagnosing problems in this thread. That's what the forum is for.
3) Oxygen Sensor Replacement
1) Disconnect Oxygen Sensor from harness.
2) Unthread Oxygen Sensor from manifold (on DX and LX models), or exhaust pipe (on EX models).
3) Reverse procedure to install. Note: Apply anti-seize compound to Oxygen Sensor threads, being careful NOT to get any on the protection tube, prior to installing.
Old Aug 11, 2005 | 06:12 PM
  #56
96haccord's Avatar
96haccord
the fuse box diagram you gave me let me fix the electical probs. on my accord, I would like to know if it is possible to get help on a 94 geo prizm 1.6? I know it's not a honda, but i was hoping you would be able to help. I just need a diagram for removing/installing the fuel pump. thanks.
Old Aug 11, 2005 | 10:33 PM
  #57
tag81's Avatar
tag81
my name is tag
ah! do you have instructions for removing the door panels on a 2002 coupe ex-v6, too? how about instructions for replacing the the door skin (outer panel)?
thanks in advance
Old Aug 12, 2005 | 05:24 AM
  #58
98CoupeV6's Avatar
98CoupeV6
Glad it helped Here's the Geo info:
REMOVE OR DISCONNECT:
Relieve fuel system pressure.
Drain fuel tank.
Rear seat cushion.
Fuel Tank Floor Service Hole Cover
Four screws and floor service hole cover.
Fuel sender assembly electrical connector.
Fuel Sender Hose Connections
One nut and fuel feed hose from sender assembly.
One clamp and fuel return hose from sender assembly.
Fuel Sender Removal
Eight bolts and fuel sender assembly from fuel tank.
INSTALL OR CONNECT :
New fuel sender gasket.
Fuel sender assembly to fuel tank; secure with eight bolts. Tighten bolts to 35 in.lbs. (4 Nm).
Fuel return hose to sender assembly; secure with one clamp.
Fuel feed hose to sender assembly; secure with one nut. Tighten nut to 22 ft.lbs. (30 Nm)
Floor service hole cover; secure with four screws.
Rear seat cushion.
Refill fuel tank.
Negative battery cable. NOTE: Turn ignition switch on and momentarily connect a jumper between DLC terminals "+B" and "FP" to pressurize the fuel system. Check for any fuel leaks.
Old Aug 12, 2005 | 05:39 AM
  #59
98CoupeV6's Avatar
98CoupeV6
thanks in advance
No problem.
Here's the PDF on how to remove 6TH GEN COUPE DOOR PANELS, as well as a diagram depicting the door assembly and instructions on how to adjust the door (sorry, no instructions on installation):
Door Position Adjustment
NOTE: After installing the door, check for a flush fit with the body, then check for equal gaps between the front, rear, and bottom door edges and the body. Check that the door and body edges are parallel. Before adjusting, replace the mounting bolts.
Place the vehicle on a firm, level surface when adjusting the doors.
Adjust at the hinges (A):
Loosen the door mounting bolts (B) slightly, and move the door in or out until it's flush with the body.
Remove the inner fender. With a shop towel (C) on the jack (D), slightly loosen the hinge mounting bolts (E), and move the door backward or forward, up or down as necessary to equalize the gaps.
Check that the door and body edges are parallel. If necessary, adjust the door cushions (A) to make the rear of the doors flush with the body.
Grease the pivot portions of the hinges indicated by the arrows.
Apply body paint to the hinge mounting bolts and around the hinges.
Check for water leaks.
File Type: pdf
Old Aug 12, 2005 | 06:14 AM
  #60
96haccord's Avatar
96haccord
just what I was looking for, thanks again!
