If anybody has specific technical or TSB questions...
Old Jun 19, 2005 | 10:20 AM
  #31
george3045@bell's Avatar
george3045@bell
georgeda
Originally Posted by 98CoupeV6
Ask them here because I get access to alldata for every car through work. It has all the TSB explanations and procedures along with an online version of helms. I'd be happy to copy some pages in this thread or email them.
Is there any information available about adding daytime running lights, like the Canadian models have, to a US 99 Accord LX 4?
Old Jun 21, 2005 | 06:52 AM
  #32
jschmid's Avatar
jschmid
Originally Posted by parkinsonrd
I have a pretty easy boring quesion. I'm wanting to replace brakes, and need to know what it takes to get the rotors off/on. I've done this many times before on other cars, but this will be the first for the Accord.
Do i need to get a puller and repack bearings or is does the rotor just slide on and off once I remove the caliper?
I can't find a stinking manual in any of the parts stores. They stock through 98.
Since you are new, I'll give you break and try to help, but yeah, it's probably been covered before and could be found by searching.
There is no need for a puller and you don't mess with the bearings. Remove the caliper and there will be two small phillips screws that basically just hold the rotor against the hub for ease of assembly. Beware though...you can easily strip the head, so I would recommend penetrating oil/lube and using an impact driver (10-30bucks) to get them off to prevent stripping. If they do strip and you can't get them out, just drill the heads off and slide the rotor off,you don't really need the screws, they just make it easier to hold the rotor to the hub when re-installing the caliper. It's the lugnuts that really hold the rotor tight.
If you live in the rustbelt like I do, even after you remove the screws the rotor may be stuck onto the hub via rust, etc. You can beat off the rotor from behind usually, but if it's really stuck like one of mine was, I had to buy some bolts that thread down into the rotor and press the rotor off the hub. Don't remember the size and pitch off hand, but just take the new rotor to a hardware store and you can find it if needed.
Schmiddy
Old Jun 29, 2005 | 09:28 PM
  #33
98CoupeV6's Avatar
98CoupeV6
lots and lots of fail
Originally Posted by TallCool 1
Great thread! I'm new to Honda ownership, and just purchased a leather seat from an '00 Accord to go in my '98 LX sedan. Can you help me with the wiring? I was hoping there was a "dummy" plug somewhere under the carpet, but Honda doesn't seem to do things that way. Any guidance you can give me would be greatly appreciated.
Thanks!
You're going to have to buy the entire wiring harness. Jschmid can help you with that, he did the same job.
Old Jul 25, 2005 | 11:44 AM
  #34
led100's Avatar
led100
I have a 1996 Accord EX with VTEC.
I would appreciate it if you could post:
98-018 JUL 03 Drivetrain - Revised CV Joint Boot Band/Installation
99-061 JUL 99 Ball Joint Removal and Installation Tools
96-050 NOV 96 Brakes - Fluid Leak from the ABS Modulator
98-009 APR 99 Engine - Ticking Noise From The Valve Train
Thank you very much.
Old Jul 26, 2005 | 06:37 AM
  #35
LowAccord's Avatar
LowAccord
Just a shot in the dark but, would you happen to have the replacement instructions for the rear wheel bearings on a 98 accord lx, 4cyl, 4dr? Or maybe since you have an online Helms, do you have an exploded view of the rear hubs? (if not, just ignore or delete).
Thanks.
Old Jul 26, 2005 | 02:17 PM
  #36
98CoupeV6's Avatar
98CoupeV6
I have everything lowaccord. For every vehicle made since like 1980. I have wiring diagrams, I have exploded views, I have detailed maintenance instructions. I have everything Helms has plus TSB reports.
These will all be posted probably tomorrow. Except for cowan...are you kidding? You just pull the thing off. And the link has been posted to see what TSBs are out for your vehicle.
Our internet has been down at work since yesterday.
Old Jul 28, 2005 | 11:13 AM
  #37
98CoupeV6's Avatar
98CoupeV6
led100 and lowaccord:
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
Old Jul 28, 2005 | 11:34 AM
  #38
led100's Avatar
led100
Can you by any chance find anything (drawing etc..) for a clogged AC drain hose on an Accord EX with VTEC?
Some people here gave me a description on how to find it but I can't locate it.
I thought since you have the resources you may be able to find something that can help me locate it and unclog it.
Thanks again.
Old Jul 28, 2005 | 11:59 AM
  #39
98CoupeV6's Avatar
98CoupeV6
Old Aug 1, 2005 | 05:45 AM
  #40
98CoupeV6's Avatar
98CoupeV6
Originally Posted by BuCxLuXoRx2o0o
can i get info on TSB 01-022
Please post vehicle type, engine and year next time.
File Type: pdf
