If anybody has specific technical or TSB questions...
lots and lots of fail
Originally Posted by teddycatnc
Do you have instructions on how to program a key fob for the 2000 Accord?
(thank you, thank you)
Originally Posted by 96haccord
would you happen to have the fuse box diagram (under the steering wheel) for a 96 accord lx auto. thanks.
Keep em coming. Remember, keep it to specific questions like a diagram or a troubleshooting method or a TSB lookup - not 'I have X problem, so search through the database for 5 mins and find it for me'
Originally Posted by Zeppo
I'm a newbee and just posted a thread looking for some help diagnosing a problem in the evap control system of my '00 Civic Ex. I was looking for a system discription, location of the pressure sensor and specs on the pressures in the system. For more info see Trouble shooting Evap System MIL P1457 (or something like that) in the Civic forum. Your help would be much appreciated.
Evaporative Emission (EVAP) Purge Control Solenoid Valve*9
When the engine coolant temperature is above 154 °F (68 °C) , the ECM/PCM controls the EVAP purge control solenoid valve which controls vacuum to the EVAP purge control canister.
Evaporative Emission (EVAP) Purge Control Solenoid Valve*4
When the engine coolant temperature above 154 °F (68 °C) , intake air temperature above 32 °F (0 °C) and vehicle speed above 0 mile (0 kph) or [A/C compressor clutch on and intake air temperature above 160 °F (41 °C)] , the ECM/PCM controls the EVAP purge control solenoid valve which controls vacuum to the EVAP purge control canister.
I'm impressed with your response time. I was trying to find a place I could view the TSB's I had found reference to but could access them.
Another part of my thread asks about the operartion of the purge valve. Do you know if the purge valve is suppose to cycle to restrict or limit the flow of vapor from the canister to the engine. Mine seemed to have a sputtering action when energized. By looking at the design of the valve it looks more complicated than a simple solenoid valve. I think there may be some internal valving that might promote this kind of action. Or not.
I copied and pasted all the info available on the purge valve already. Sorry.
Edit: Found one more.
Originally Posted by BuCxLuXoRx2o0o
hey 98coupev6, i gotta another one for you if you dont mind. i have an SRS light on and the code stored is 9-3. its for a 00 accord coupe 4 cyc. lx model. any info is appreciated...TIA
Siemens unit (I believe only side air bag models):
i got one for you if you dont mind, i clicked the link that you provided and its trying to charge me $25 for the first and $15 for the others...
obviously im a noob... sad to say, but im learning my way around...
i have a 95 prelude si with the following problems:
passenger side door can unlock whole car with any key
i have an abs light that blinks once (dont know where to look to find out what it means)
and dont know if its a TSB issue or not, but also my clutch makes a noise as im letting it out. and its not the pedal...
any info you can help me with i appreciate it, or if you could show me to somewhere that will help, that would be great too...
thanks,
brandon
thanks,
brandon
Originally Posted by wedley2
90 accord f22a4 (EX)
all i need is torque specs for like the clutch and transmission. thanks a bunch!
COMPONENT TORQUE
CLUTCH COVER 6 X 1.0 mm bolts 12 Nm (9 lb ft)
PRESSURE PLATE Mounting Torque [1] 26 Nm (19 lb ft)
[1] Tighten the bolts two turns at a time in a criss-cross pattern.
TRANSMISSION TO ENGINE 12 X 1.25 mm bolts 65 Nm (47 lb ft)
RING GEAR Bolts 101 Nm (74.5 ft. lbs.)
SHIFT CABLE BRACKET 8 X 1.25 mm bolts 22 Nm (16 lb ft)
TRANSMISSION BRACKET TO TRANSMISSION 10 X 1.25 mm nuts 39 Nm (28 lb ft)
MOUNT TO TRANSMISSION BRACKET 10 X 1.25 mm nuts 39 Nm (28 lb ft)
MOUNT TO BODY BRACKET 12 X 1.25 mm bolt 65 Nm (47 lb ft)
REAR MOUNT BRACKET STAY 10 X 1.25 mm nut 21 Nm (15 lb ft) 10 X 1.25 mm bolt 39 Nm (28 lb ft)
Originally Posted by 98CoupeV6
Ask them here because I get access to alldata for every car through work. It has all the TSB explanations and procedures along with an online version of helms. I'd be happy to copy some pages in this thread or email them.
Originally Posted by AMA Racing
I am working on a 94 Accord and seem to be in a bind.The car has a sluggish jerky motor when you first accelerate and then seems to smooth out once you get going.I held the brake and gave it a little gas and it does it too.The car idles fine and runs fine once you get going.I have given the car a complete tune up being i replaced the wires,plugs,cap and rotor,fuel filter,air filter and the pcv valve..so i waswondering if maybe the timing belt jump a tooth or could it be something else...its got me puzzled ..any help would be great ..thanks
