HID kit questions
Old Dec 26, 2004 | 07:00 PM
1998accordlx's Avatar
1998accordlx
VTEC INSIDE
whats is the K value for the the kit that comes on the S2000 ???? cuz i don't want them to look yellow like my stock ones the whole point is to get that blueish color out would 4300K do that??? post pics if you can please
Old Dec 26, 2004 | 07:28 PM
hondajeff's Avatar
hondajeff
go with the 4300k bulbs if you want the s2000 look. I had done a retro fit in my old civic a while back with s2000 projectors and it looked awesome. S2000's and the TL's both use 4300k bulbs.
go to this site to discuss hid stuff and retro fitting. thats all the members on this site do......http://www.network54.com/Forum/216460
Old Dec 26, 2004 | 08:08 PM
FLip wit da Flo's Avatar
FLip wit da Flo
i was planning to put them in my stock housing, my neighboor has a TLtype-S and he doesn't have the lens projectors?? so i can't put them in my stock housing?? that must suck
I know this was already answered. The reflector is designed to hold that HID beam, but i'd like to add that the bulb is different from Projector bulbs. Reflector HID's use D2R (such as those in the last generation TL's, IS300's, G35's., and projectors use D2S ( such as the one shown above with the retrofit, BMW's, Benz.) Just be on the lookout which one you buy.
Old Dec 27, 2004 | 05:07 AM
flyromeo3's Avatar
flyromeo3
Originally Posted by hondajeff
I have a kit in my factory headlamps as well and I don't have any annoying glare. I would recommend you stick with somewhere between 4000-4300k. 6000k looks too purple. the higher the number the more the color changes but output decreases. 99% of cars with oem hid are 4300k. philips has made 5000k bulbs to replace the 4300k but not sure if there is a huge difference.
I think once you go above 8000k they get a bit purplish...........
Mine from a distance have a blue/ white tint to it.
They arent as blue as you would see an 8000k bulb.
its funny cause the philips 6000k bulbs I had were a bit purple.
Now with these Eagle Eye 6000k bulbs I have they are a bit blue.
I guess it depends on the manufactor
Old Dec 27, 2004 | 08:41 AM
skabone69's Avatar
skabone69
Originally Posted by tim3090kc
Your setup looks pretty sweet. How much did that run you? Any idea where I could get some info on how to do a retrofit for my 99' ?
that's not my setup, its just an example of the work 99AznAccord does. check out http://www.bwimports.org/forums/show...hp?p=84#post84 if your intrested in a retro setup.
Old Dec 27, 2004 | 01:36 PM
1998accordlx
VTEC INSIDE
i don't really understand what retro mean is it the same as they would take the stock housing cut it out and put a lens projector in it ???? by the way flyromeo3 can you please post some pictures of your hid's cuz you just left the in the stock housing right?? and how it was said i should buy a DR2 kit??
Old Dec 27, 2004 | 09:09 PM
FLip wit da Flo
well yeh if you gonna use your stock reflectors you gotta get the D2R kit.
Old Dec 28, 2004 | 05:35 AM
H-Accord-22's Avatar
H-Accord-22
Duh
D2S is use with projectors and D2R are for use with reflectors
Old Dec 28, 2004 | 06:54 AM
FLip wit da Flo
we already established that. thanx though
Old Dec 28, 2004 | 08:36 AM
skabone69's Avatar
skabone69
what I mean by retro is that you get a set of BMW projectors, Audi projectors, Acura projectors, or Evo projectors(whatever car company makes a projector), and you mod a set of headlights to make the projector fit and work properly. the pictures I posted were Evo projectors modded to fit an accord housing. the beam pattern will look as nice as a factory HID setup.
