HID kit questions
Old Dec 22, 2004 | 11:38 AM
skabone69's Avatar
skabone69
Originally Posted by SumAccordGuy94
putting HIDs in ANY stock halogen reflector headlight WILL blind oncomming traffic. Only ways around this is to retrofit OEM HID Projectors or make a shield that will cover the bottom half of the HID bulb. Ok, now that thats over and done with... stick with 4300-5400K OEM bulbs... anything higher and you lose alot of output, almost making a HID kit worthless.
Also keep in mind that you'll have a ton of stray light and "hot spots" as the halogen reflectors are not made to work with such intense light. Nothing beats OEM HID projectors or reflectors and you'll never come CLOSE to the output of either with HIDS in a halogen housing.
:werd: well said. pls do a retrofit, there are a few guys out there that do some quailty retrofits that look sweet. I love the work 99AznAccord does, and illusion lighting does a great job as well. I also agree with the bulb power to get. anything higher than 5400K and your going for the bling factor.
Old Dec 23, 2004 | 07:29 AM
SumAccordGuy94's Avatar
SumAccordGuy94
Older Honda Fanatic
might i suggest these rather neat shields... here
just found 'em, seem like they'd work wonders for any HID kit in halogen housings!
Old Dec 23, 2004 | 11:31 AM
1998accordlx's Avatar
1998accordlx
VTEC INSIDE
i was planning to put them in my stock housing, my neighboor has a TLtype-S and he doesn't have the lens projectors?? so i can't put them in my stock housing?? that must suck
Old Dec 23, 2004 | 11:42 AM
skabone69's Avatar
skabone69
well your neighbor's TL housing are designed to handle a HID beam. our accord housings are not designed to properly reflect a HID beam. the reason we say a projector is the way to do it, is it is one of the best ways to get a properly working HID setup for an accord.
here is an example of some nice retro work.
And here are some on the car:
99AznAccord did these, some quality work.
Old Dec 23, 2004 | 01:29 PM
1998accordlx
VTEC INSIDE
tanx for the good help guys it seems like i need to get the proper housing first now one more question once you upgrade the housing your light bulbs are not goin to be 9006 low beam right??? i think it will be H4 H3 or something like that if i'm not wrong.
Old Dec 23, 2004 | 01:50 PM
skabone69's Avatar
skabone69
correct, if you upgrade you'll have to use the HID bulb that goes with the proper projector.
Old Dec 23, 2004 | 10:28 PM
1998accordlx
VTEC INSIDE
is there any way i can get aroud it by using the stock housing??
Old Dec 24, 2004 | 10:35 AM
Jehu's Avatar
Jehu
Those look friggen hot..
i got a 92 accord exr,
any light sugestions?
projection?
Old Dec 24, 2004 | 09:04 PM
tim3090kc's Avatar
tim3090kc
Your setup looks pretty sweet. How much did that run you? Any idea where I could get some info on how to do a retrofit for my 99' ?
Old Dec 25, 2004 | 03:33 PM
hondajeff's Avatar
hondajeff
Originally Posted by flyromeo3
Negative............I slapped in the HID kit into my stock housing and I dont produce any glare onto on coming traffic... ( Tested this out )
Maybe since I have those eyelids maybe it decreases glare?
I have a kit in my factory headlamps as well and I don't have any annoying glare. I would recommend you stick with somewhere between 4000-4300k. 6000k looks too purple. the higher the number the more the color changes but output decreases. 99% of cars with oem hid are 4300k. philips has made 5000k bulbs to replace the 4300k but not sure if there is a huge difference.
