B18C5 or B16B?
Originally posted by AdtCivicSi
Is his car pretty quick? Do you know any 1/4 mile times?
Why not just rebuild your motor?
Sleeve and bore it out to like 85mm with some weisco pistons, add a C1 or C5 crank and P&P the head and toss in some skunk 2's. Add SMS header and a custom 2.5" exhaust & cat. Tune it with hondata and you should be very happy.
Originally posted by thaveen
if you buy a jdm b18c1 you can get an lsd on it. and buying an engine is no time to dislike something for no reason. but if you want to waste money then by all means, by a type R engine
Sleeve and bore it out to like 85mm with some weisco pistons, add a C1 or C5 crank and P&P the head and toss in some skunk 2's. Add SMS header and a custom 2.5"; exhaust & cat. Tune it with hondata and you should be very happy.
99 Integra GSR
06 TSX
duck squad member #00003
99 Integra GSR
06 TSX
Originally posted by 94civicEX
The motor is still a B18C in Japan, but is out of a SiR-G. Difference being +10 horse, +1 lb ft torque, 10.6:1 vs 10.0:1. The USDM tranny is the Y80, and the JDM is the S80 with optional LSD. The gear ratios are the same but just the LSD option.
Now that sounds like a good idea :drool:.
h:
