Rear Disk Conversion
Old Jul 20, 2002 | 06:27 AM
  #41
Fujiwara Takumi's Avatar
Fujiwara Takumi
It's my first day.
Originally posted by H-A Stud
:werd: My 95 cp came from the factory with em :thumbup:
:fawk:
Old Jul 20, 2002 | 06:32 AM
  #42
Fujiwara Takumi
It's my first day.
Originally posted by crucial Si
will it make stopping worse?
abs is no fun for racing.
Old Jul 20, 2002 | 06:44 AM
  #43
Fujiwara Takumi
It's my first day.
Originally posted by skubb
what exactly are the trailing arms?
also is it common for this part to be a little weathered and corroded looking but still be in good shape?
I know of a 95 teg lying aroung but I'm not sure if they're in good enough condition to use.
trailing arms run lengthwise with the car..attach to the drop a-arm in the back.
when you push your wheel up and down you should see two large pieces of metal moving...the one heading the center of your car is what i call the lower a-arm -- which i donno is right, and then the trailing arm is just what it sounds like...the one that runs parallel to your "trail."
Old Jul 21, 2002 | 07:07 AM
  #44
Fujiwara Takumi
It's my first day.
Originally posted by ManInCamo
Tons! probably cost more than the car is worth. Thousands. the abs system, abs brake lines, abs wires, abs sesnors. dozens of hours of labor.
mines got the wiring for ABS, dont i just add the ABS components to the brakes and be done?
Old Jul 21, 2002 | 07:54 AM
  #45
Duff Man's Avatar
Duff Man
If you don't know what the trailing arm is...I wouldn't recomend doing this project alone h:
Old Jul 21, 2002 | 07:56 AM
  #46
Fujiwara Takumi
It's my first day.
actually, you make a good point. its really a common sense thing, if you cant figure it out...:ugh:
Old Jul 21, 2002 | 09:31 AM
  #47
Fujiwara Takumi
It's my first day.
here's that rear AEM conversion almost 200 dollars cheaper than the other site i saw on this thread:
http://www.importhorizon.com/civicbrake.html
Old Jul 21, 2002 | 05:40 PM
  #48
ISP James's Avatar
ISP James
DAMIMRED
still too expensive for me, i dont know it has to be tons cheaper to do it via salvage cars.
Old Jul 21, 2002 | 05:56 PM
  #49
Fujiwara Takumi
It's my first day.
werd, i saw almost a complete salvage for $304 on ebay today, that was alright. id pay that, then get some brembo rotors/aem pads...
Old Jul 21, 2002 | 07:05 PM
  #50
incublinkus's Avatar
incublinkus
JDM Fan Boy
I heard the AEM kits was good but it squeaked alot. Is the AEM conversion kit like a GSR/Si swap only with AEM rotors and Pads? or is it something custom made by AEM and different completely?
